Rough in of Pex though concrete floor
  • Rough in of Pex though concrete floor
    I'm new to this so be kind. Pex has just be approved in my area of Nebraska, and I'm looking at a job that require Pex piping. I will need to rough it threw a concrete slab.
    Any suggestions on the proper method.
    Re: Rough in of Pex though concrete floor
    make sure you run it in a conduit.
    Rehau can supply it already sheathed for this application. Cant remember the product code right now.
    If crossing a slab run a spare conduit/s or pex line/s just to have options when things get broken by the concretors.
    and make sure you are there when the slab gets poured, ready to make emergency repairs.
      This is the system for wirsbo made by uponor
      Pre-sleeved Wirsbo AQUAPEX Tubing
      Uponor has added red and blue high-density polyethylene (HDPE) corrugated sleeves to 1⁄2" Wirsbo AQUAPEX┬« tubing for use in hot and cold water distribution systems. The corrugated sleeve provides protection for installations in concrete slabs or soil, and allows for easy removal and replacement of the tubing if required. In addition, the red and blue color-coded sleeves easily identify hot and cold water lines.
      I am sure rehau makes somethign also along htese lines, it is easy, but I am sure it comes with at a cost.
      Robert
        Thanks for the information. I will talk to my supplier about these sleves. thanks again.
