plastic plumbing
  • plastic plumbing
    Does plastic plumbing require earthing?
    Re: plastic plumbing
    you plumb in plastic, even if you use copper tails on the exposed pipework, you don’t need to earth bond the pipes.
      Out here the electrician is required to ground his panel to our system,then we are required to have up to 10' of copper in the ground.
