some of jobs picts
  • some of jobs picts
    I'm posting this for my hubs!! He will edit the post after dinner(descriptions)
    Robert
    Re: some of jobs picts
    I think I see a small problem here ......rotflmao
      LOL, that is just sitting there resting, it is not glued in place, I set it there so everyone would know there is a toilet there
      Robert
        I know there must be a reason for two sets of stubouts on one side of the wall . . .
          And?
          the dog
            2 colds, one for the k/s faucet and purification faucet
            2 hots, one for the k/s faucet and dishwasher
            there is also a cold for the hoise bibb going out the back.
            eliminates the 2 way angle stops
            Robert
              you know I just had to do it
                Aha! It's a kitchen. I always plumbed my water lines out of the floor for easier future repairs.
                And I used copper tees under the sink for things like a dishwasher. And I never needed a purification faucet. We have good water. Plus, I usually had the sink drain to the left of the water lines, to line up with the left side strainer. (Wash on left, rinse and disposer on right.)
                I don't do construction or remodels anymore, so I get to miss out on all that stuff like composite counters and undercounter sinks.
                  And the kitchen water supplies have an 18" spread centered on the sink to keep the sprayer hose from hanging up.
                    no that is actually the finished elevation.Its the siesmic floor for earthquakes.Robert just hasn't hung the #12x8" brass screws in the flange yet to hold it to the float
                      Actually the waters were coming out of the floor, it was a cheap re-pipe. I move all my stuff in the wall, it looks better and is cleaner.
                      Robert
                        [quote=westcoastplumber;106705]I'm posting this for my hubs!! He will edit the post after dinner(descriptions)
                        robert, i don't want to be the one to bust your chops but a grundfos circulating pump can't be installed with the shaft in a vertical position. a horizontal position is the correct orientation.
                        you will be installing a timer too
                        also i like a union on the prv discharge line.
                        otherwise nice installation.
                          [quote=PLUMBER RICK;106727]
                          Hmmm, it will be changed on monday. Yeah, a union can be nice on a t&p.
                          I don't do electrical work, the timer will be installed by and electrician, along with a switch to turn it on and off.
                          Robert
                            Robert,
                            What type of switch is being used to activate the HW recirc. pump? Timer or Thermostatic Sensor?
                            Does code require you to completely hard pipe the gas supply?
                            I normally use the Brasscraft gas flex with the included ball valve.
                            Great Job Robert, this is the way I do it also, always 4 stub outs for the Kitchen Sink, regardless if the plans/specs show a dishwasher and/or ice maker/purifier.
                            It never fails, 2 weeks after the owner moves in, you get a call..."we wanna add in an Instant Hot, or Water Purifier, etc."
                            Good wide spread on the Hot & Cold supplies. I also do this, allows for a lot of free movement in the cabinet for those pull out spray hoses. Don't ya just hate it when the pull out hose catches on the angle stop?
                            Are Long Sweep Elbows required by code there? Here the code allows us to use the Medium Sweeps for offsets below flood rim height.
                            The cabinet installers will shoot me if I do that. If structual conditions allow it, I always stub out of the wall.
                            To me, by stubbing out extra pipes, it eliminates the need to torch inside of the cabinet, especially with the high end european cabinets now a days. If you are gonna bring out the torch, it might as well be during the rough in stage.
                            I find that placement of the disposer really depends on the homeowners washing habits and/or placement of the dishwasher. Whatever they decide, you are safer by stubbing out in the center.
                            FWIW, the stubout should be on the disposer side, not on the strainer side, this way the disposer shoots straight down the baffle tee.
                            These are just my opinions, Robert's may be different.
                            Tracy
                              Yasuda, m/s are required by code, they do not have to be long sweeps, it is what the guy at the supply house threw in the box, and I didn't unpack until I got to the job site, m/s are fine, but to late to change.
                              As long as we have a drain fitting below the flood level rim of the fixture, thats whats important.
                              Robert
