300 electric problem
  • 300 electric problem
    my 300 quit working last night. it is not getting power. i thought it might be on off switch or foot pedal. does anyone know of common problem and how to fix? thanks don
    Don,
    There are a couple of things I would look at initially. The first step is to take a look at all of the connections on the machine to ensure that they are in tact and nothing has inadvertently pulled loose. There is a procedure that will allow you to bypass or "hotwire "your motor directly to the power cord in order to determine if the switches are the culprits. I would recommend that you contact our technical service department for more details on this procedure. They can be reached at 1-800-519-3456.
