PVC vs ABS
  • #46
    Re: PVC vs ABS
    Tell me you don't use nail-ons.
    j-hooks painted copper color.I can get a box of a hundred for $19.95.Just push the copper over to the stud and nail off.Better to use "m".
    • #47
      Re: PVC vs ABS
      What kind are you talking about that's bad? Are you talking about these?
      http://www.siouxchief.com/Frm_MS.cfm
      • #48
        Re: PVC vs ABS
        The ones I was joking about were called J-Hooks sometimes called nail-ons by a few guys that would migrate through our company back in the early nineties.The fully enclosed ones you and Robert are referring to aren't bad as long as you are away from the face of the stud far enough to where the drywaller can't reach your copper with a stray screw.The "C" style are unacceptable
        • #49
          Re: PVC vs ABS
          Adam, these are what you refer to as "nail ons"?
          • #50
            Re: PVC vs ABS
            Tube Talons I'm sure you all know work great during new construction and hold well.........
            but give it a few years and every one of them will break/snap right off if you pulled that piping into position.
            The job I was at yesterday had all the copper hanging by itself, all the tube talons were snapped off whether black or gray.
            Those copper clad drive-in J-hooks are pretty reliable, always hold the piping tight.
            I use the longer plastic/white J-hooks with numerous holes that are 6" long. You can use the nails that come with them or use screws.
            Every time I use those drive-in metal wire hooks I always bend the tabs and it screws up the height I want them. They look purdy though.
            • #51
              Re: PVC vs ABS
              Okay as long as it was a joke I guess I can sleep tonight.
              • #52
                Re: PVC vs ABS
                Yes,they are in this link
                • #53
                  Re: PVC vs ABS
                  I couldn't if I had your cat in my house!!!
                  • #54
                    Re: PVC vs ABS
                    In My Opinion Pvc Wins!
                    1) Less Sound, You Can Hear Water In Abs Draining In The Walls
                    2) Abs Is Crooked
                    3) I Was Sold After I Did An Abs Repair On A Dishwasher Drain In A Restaurant. Pipe Was Leaking Cut Out A Section Coupled In A New Peice Was On My Way. Two Months Later Called Back Did It Again. Another Few Months Another Call, The Pipe Kept Splitting I Know Each Fix Plus The Original Were All Different Lengths Of Pipe, Went From The Unit This Time + Ten Feet With Pvc Then Joined Together With Male Female Adapters Has Been Six Years Trouble Free.
                    Abs Is Made For Speed, No Primer Solvent Weld, You Have To Be Quite Careless To Fail An Air Test. That Is The Only Advantage Is A Chemical Weld In The Joint.
                    • #55
                      Re: PVC vs ABS
                      I was talking about the 3/4" x 6" hangers, that you install with a hammer.
                      The j hooks, nasty, nasty, nasty, I repair so many leaks with these.
                      Robert
                      • #56
                        Re: PVC vs ABS
                        Interesting,well,some are made of copper.Do I just bend them over the leaky pipe and solder OR drive them through the hole then solder
                        Outs in dee's heah pahts dae's calls'um wire hooks.
                        • #57
                          Re: PVC vs ABS
                          Lobstah?
                          • #58
                            Re: PVC vs ABS
                            Originally posted by DuckButter View Post
                            Lobstah?
                            Better!
                            Stuffed Quohogs!( Falmouth,Green pond )
                            • #59
                              Re: PVC vs ABS
                              We use nothing but PVC...
                              I don't much like the ABS anyway.,...
                              • #60
                                Re: PVC vs ABS
                                Abs Is All We Use Out Here If Your Worried About Mess When You Cut It Use A Wheel Cutter Works Great Nice Clean Cuts, Also Strapping With Plastic Plumbers Tape Its Very Rare To Have Noise With Abs
                                Mike
                                www.plumbinginclarkcounty.com
