Press tool
  • Press tool
    Any one own a Rothenberger Romax pressing tool. Bought one used from ebay, seller says it worked perfectly. I cannot get it to do anything. Does any one know what the normal functions are such indicator led. Am I an idiot and just overlooking something simple, or is it time to send it back.
    THE GLASS IS ALWAYS HALF FULL
    Re: Press tool
    ben passed on that unit. i would suggest you download the owners manual from their website and then try it again.
    first sectional questions and then pressing questions.
    sounds like the time off made you a changed man
    what next? jetters, pipe freezers, trenchless
      Re: Press tool
      I have had a pro press for some time and used sectional machines in the past. When I saw the romax , thought it would be a good back up.
        Re: Press tool
        as a backup you probably want to stick with the same jaws. are the jaws interchangeable?
        i thought it was a good idea to have a back up too/ five
          Re: Press tool
          Yes, the jaws are interchangable. It came with 1/2 through 2 inch. So regardless ,I have a full jaw set. The last time I repaired anything larger than 2 inch was about 7 years ago. At that time the supply house did not carry Viega fittings.
            Re: Press tool
            here is a link to the rothenberger romax ownersmanual pdf.
            http://www.usa.rothenberger.com/file...00_OM_0406.pdf
              Re: Press tool
              I sent back the Roth, and purchased a new complete Pro press set today. After trying to get service for the Roth I decided that Ridgid would be better. The guys at tool depot had never even seen one before. They kept referring to it as a Ridgid pro press.
