Orangeburg pipe cutting
  • Orangeburg pipe cutting
    Just curious I have never cut orangeburg pipe with my snap cutter before, it looks to be out of round and I have a lot of it to cut in really tight spots. But because it is oval now I thought maybe the snap cutter might not be so trusty this time. I can use my 14" cut off saw but would rather use the snap cutter. Anybody ever run into problems before?
    Seattle Drain Service
    Re: Orangeburg pipe cutting
    Depending on the age of the pipe it might have been made to be oval. Either way you should be okay as long as you coupling it properly. Here is a link check it out.
    http://www.sewerhistory.org/grfx/com...pipe-orng1.htm
    THE GLASS IS ALWAYS HALF FULL
      Only one thing to do with orangeburg pipe....replace the whole line. Thats the only option I give my customers. A plumber finding orangeburg in the ground is like a doctor finding cancer...time to operate.
        The few times I've run into orangeburg I've cut it with a sawzall with either a metal or wood blade (the blade was not made of wood).
        I worked Seattle for a long time and never ran into orangeburg there. Out of curiosity where did you find it?
        Brent
          I have run into fibre pipe on about three ocasion over the last decade. As long as you can coupling it alright and there are no roots close, you will be alright. Of course cover youre ss with the clent and make them aware of the situation. If for some reason the pipe is above ground I would definetly replace it. If the outside run is not too long then replace it. However if money is an issue then just tie into it.
            a sawzall with wood blade 6 -10 tpi.
            the real issue is the transition coupling. sometimes an all rubber fernco/ mission coupling is the only one that will adapt.
            i thought it was only for area drains, then i ran into it for a sewer
            hard to snake an oval pipe.
              Where i live its all 3in Orangeburg pipe for the main sewer lines.
              I had to put a cleanout in on my pipe, cut a section out with the sawzall. The pipe was oval, and when pulled the cut piece out, i crushed it with my hands. Hardest part was banding the new piece to exsisting pipe. Had to use ferncos.
                It's been a while but I think a regular PVC TO PVC fernco won't usually work.
                I think I usually ended up using a PVC to Cast Iron or asbestos cement.
                The O.D. can vary quite a bit with Orangeberg so have a few different size Fernco's on hand.
                  In a pinch, I've even cut it with a plastic handsaw. Most often it seems as if the interior of the pipe is delaminating. I always recommend ripping out all orangeburg.
                    This is being used in a large man made old old pond in the Wallingford district.
                      Many of the older tracts of houses in my area have orangeburg Rick.
                      If you were ever to increase you're six mile range you might have an opportunity to see how the rest of the world works.
                      Sorry my friend you left it out there,I had to take the sweet shot.
                      I would hope you'd do the same for me
                        Don't ever use a snap cutter on orangeburg. It'l lock togeather ,and become junk!
                          we run into oarngeburg all the time, and if there is anything left to work with plumber rick is right use your sawzall, then we use a clay to plastic ferncos to tie, in but our first recommendations is always to replace the line hate to put a band aid on anything but allot of times a custmer financial situation will dictate the rule of the game.
                            I still have Orangeberg at my house (39-years and counting). As has already been mentioned you cut it with a wood saw not a snapper. If you give Fernco a call they will tell you which coupling is the best to use as they don't list one but do recommend one. In the old days you hy
                            ad to use an Orangeberg lathe (hand too) at the couplings but I have not seen one of those in decades.
                              we still have one believe it or not its been long retired but still fun to show the newbies
