Service Plumbers Tools
  • #31
    Re: Service Plumbers Tools
    Been mostly using my Makita 14.4V Sticklight (what I call it). Came in an Impact Driver, Drill, Light kit. Works great and lasts a long time on LiOn batteries. Got a hanger on it too.
    • #32
      Mine died awhile ago, and I miss it.
      • #33
        To remove pex rings on brass fitting , use a torch and and a couple of water pump pliers. As long as it's not still attached on the other side of the fitting. I do this on fitting I used for air tests. Just warm up the pex till it gets a little glossy and pull the ring and old pex right off.
        I use the Veto XL, and there are many days it never leaves the truck , it must go at least 75 lbs. You would be amazed on just how much I can do with a 12" set of water pumps, a six in one screw driver and a 6" adjustable wrench.
        • #34
          That's why I use the LC. I knew if I got the big one I'd fill it up and never take it out cause of weight.
          I also often go in blind with pretty much the exact three tools as you.
          • #35
            I got a Lennox 9 in 1 about a year ago.
            It's made to not warp when used for hex nuts, can do 1/4", 5/16" or 3/8", small flat head, large flat head, as well as philips #1 & 2.
            I was going through 6 in 1's every two months over the fact that the hex drivers were warping so fast.
            • #36
              Get a Klein.
              • #37
                Yep. Nut driver on my Channellock 6 in 1 almost stripped out. Thought I'd buy the RIDGID one. Catalogue#16573. Says it has an extra thick wall to prevent this and....
                The RIDGID lifetime warranty.
                They used to just swap handtools out if you had a problem at the supply houses if it was under a certain dollar amount.
                Josh or someone, do they still do this? What's the written policy?
