Check valve covering a cleanout
  • Check valve covering a cleanout
    Why don't we use these to cover outside cleanouts instead of caps or plugs? This way if the lines back up, the cleanout will open up outside instead of backing up and flooding the house. The homeowner will see the water and call a plumber and no water damage(in theory). Of course the cleanout needs to be able to unscrew to get access to the cleanout. Any disadvantages?
    Re: Check valve covering a cleanout
    A couple of decades ago we were putting them on.Then they started making us put in backwater valves.
    Contamination.
      Here, these sewer poppers are being required most places.
        Never ran into either one in this area.
          On an interior c/o.... well never mind that's not your point. On an exterior c/o cause it'll let gas out and stink. And i'tll just plug with paper and back the house up anyway, or fail and let cold air in to help the line freeze.
            ben on an outside clean out that will not cause any damage, most of out here tend to leave a jim cap loose and alow it to pop off into the garden.
            of course the homeowner needs to be aware of this and realize it's a stoppage.
              [ATTACH]2793[/ATTACH]
              [ATTACH]2794[/ATTACH]
              They are starting to require these allot more around my parts, La mesa San Diego
              THE GLASS IS ALWAYS HALF FULL
                I HAVE SOLD MANY OF THESE FOR SEWER CLEAN OUTS THOUGH OUT THE SO. CALIF. AREA WHERE THE SEWERS DO NOT FREEZE THEY HAVE A LARGE
                PLASTIC BALL INSIDE THAT BLOCKS SEWER BUT
                FLOATS UP TO RELEASE SEWER OVERFLOW IN
                CASE OF MAIN LINE BLOCKAGES
                [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
                [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
                JERRYMAC
                E-MAILJERRYMAC777@GMAIL.COM
                FIRE SPRINKLER CONTRACTOR,
                SINCE JAN. 1989
                  Those C/O will never work in west michigan. builders, new home plumbers and homeowners insist on having the C/O under the dirt, so they can never be found when needed.
