kohler dtv shower system and enough hot water
  • kohler dtv shower system and enough hot water
    kohler dtv shower system, the customer lives on a acrage. So i am concerned about the amount of water and hot water that is required to run a system like this. There is a total of three and a half bathes in the house, 2 x dishwashers, 2 x washing machines, 5 people(2 adults three teenagers). they have a trickle system that supplies 30 gph. I figure a 20 min shower with the dtv will use 21 gpm wich would be about 420 gal. Thats not taking into conceseration of the other to showers running at the same time. HAs anyone put this system in and run into a similar problem
    Re: kohler dtv shower system and enough hot water
    They are going to need large storage tanks at the well, and probably a few tankless water heaters to provide the hot water for the home. Is the shower piped to handle that much water? Most of the ones I see are not. Make sure there is more than just one two inch shower drain, or that shower will turn into pool real fast.
