Cutting 2" flowgaurd,corzan... Page Title Module
  • Cutting 2" flowgaurd,corzan...
    Just curious as to what you guys use to make cuts on the larger stuff,I've been forced into hand saws,but the shavings are intolerable.
    Re: Cutting 2" flowgaurd,corzan...
    Large PVC cutters,tubing cutters designed for plastic pipe(up to at least 3") if you don't like shavings.
    I use a skilsaw on production,some use a sawzall(PVC-ABS)
      I use the Ridgid 154 tubing cutter with a plastic cutting wheel then I use a NO. 73 deburring tool to take the edge off.
      ________
      Yamaha Sa2200 History
      Mike
        I think there's a guy on the forum that would probably use an axe
          I'm not a mind reader!!! Let's hear it.
            Hate to bring up old thread, but can you cut 4" ABS or PVC with any tubing cutters with plastic wheels?
            One co-worker has Reed's but they max out at 3". I'm guessing the Ridgid's do too.
              I use my large Ridgid cutter with a plastic wheel in it to cut 4" ABS fairly often.
                Chop saw
                ridgid pvc cutter
                Lenox pvc hand saw
                  I prefer the term "hatchet".
                    I just left the PHCC show in Orange County with a new Milwaukee 12v PVC cutter. It will cut up to 2" PVC. It won't be a tool that everyone would need, but for my area, I think it will save some wear and tear on my hands over the years. Maybe someone else will have a good use for it also.
                      On production jobs I use my 12" miter saw with a fine blade.
