Sump pump SP500
  • Sump pump SP500
    I have a Rigid 1/2 HP Pedestal Sump Pump SP500
    I am having a problem with the on/off switch at the top of the unit. Sometimes at night the pump will not shut off after a cycle. I checked that the float system was clear and added a little weight to the ball cock rod. The problem is intermittent and I'm not sure if I should return the pump to Home Depot ? Any suggestions?
    Thanks in advance
