blue water
  • blue water
    blue water coming out of the 1/2'' copper when i went to remove a compression hose bibb.
    the neighbors house had a 1/2'' compression bibb leaking right next to the stucco wall. i used my puller to remove the nut and ferrul. as i was working the puller, the water was still coming out, all of a sudden there was a bright blue tint to the water.
    i finished and asked the owner about there toilets. turns out the upstairs toilet had a fluidmaster 400a that was set too low and not 1'' above the (critical level), overflow.
    i guess the 1000 flushes siphoned back into the potable water.
    now i have a cheap way to get cool aide
    go to the neighbors house and shut off the main turn on the bibb and fill r up
    amazing
    Re: blue water
    Thats a new one I haven't heard before. I hope you put a new fill-valve in.
      Re: blue water
      Great case for the debate on using lead solder for those who don't really think backflow is real.
        Re: blue water
        Backflow preventer.?
          Re: blue water
          Absolutely,
          So,now...Everyone with a copper water system installed before the implement of 95/5 need to be informed they need to get their home repiped imediately.
            Re: blue water
            I thought they had a back siphon or even back flow feature built into them?
            Maybe it went bad/broke?!
            Proud To Be Union!!
              Re: blue water
              Absolutely,
              Whoo! Hoo! I'm going to be rich cashing in all that copper at the scrap yard
              This happens everyday in millions of homes. Rick only noticed it because of the blue dye.
              The homeowner might want to hold off doing that load of white laundry
                Re: blue water
                the 400 ballcock has an anti-siphon built into it.
                the ballcock was installed too low. the critical level needs to be at least 1'' above the overflow pipe. the water level was high as the ballcock was not shutting off and the level was higher than it should have been.
                so because of this, i picked up on the toilet issue.
                this happens all the time with water heaters. there is an anti siphon hole in the top of the dip tube to prevent the heater from siphoning the whole tank.
                  Re: blue water
                  Rick, was this on a condo or apartment that shares a main water line?
                  ________
                  FORD FREDA SPECIFICATIONS
                  Mike
                    Re: blue water
                    this job was on a private 2 story home.
                    not too sure i would have found the culpret in a condo or apartment building.
                    there were only 2 toilets in the house and the upper one had the blue 1000 flushes in it. still appeared to be 999 flushes left in that muck
                      Re: blue water
                      Absolutely,
                      If I had a nickel for every DIY I see looking around online that's told "lead solder or 50/50 will be easier to use if you aren't familiar with soldering", I'd be retired.
                        Re: blue water
                        Your right Rick! I miss read your original post and thought you were working on a neighbors house of the one that had the tidy bowl blue problem. I was having a mind melt at the time
                        ________
                        Ford kuga picture
                        Mike
                          Re: blue water
                          Rick
                          We have had this problem in Melbourne for many years and have had every explaination under the sun from electrolysis to the actual copper piping reacting to the water in the pipe.
                          I don`t use copper for hot or cold water renewal anymore I use a product called Rehau and this and other PVC product are being used here.
                          Regards
                          Tony
                            Re: blue water
                            Originally posted by AFM View Post
                            Rick
                            Regards
                            Tony
                            Tony,
                            I believe you are talking about the copper leaching out of copper pipe while Rick is talking about a water closet ballcock which siphoned blue chemical tank water into the potable water because the C/L of the ballcock was too low.
