What's your diagnosis quiz
  • What's your diagnosis quiz
    Ok, a customer called yesterday very concerned about a plumbing issue because he was leaving town in two days and wanted to get it resolved.
    I asked him three questions over the phone to form a tentative diagnosis and confirmed it later with a trip to his house.
    Here is what he reported. I'll tell you the first 2 question and answers. What do you think the third question and diagnosis is?
    "I've got a leak in my yard and I think it's the sewer backing up. It smells like sewage. I was aerating my front yard and when I got through I noticed a hump in the ground and a root, about as big as a broom handle, coming out of and going back into the ground. I cut the root in two places underground. I must have hit a pipe or the roots must have broken the sewer pipe because the ground is wet and bubbling and we have been using water in the house."
    1st question: Did you see a vertical piece of pipe or a cleanout near the water? Answer: No.
    2nd question: Did you see any other pipes around where you cut the roots?
    Answer: No
    3rd question: ?
    Diagnosis: ?
    Re: What's your diagnosis quiz
    Do you have a sewer pump? Hit the line?
      Are you on town sewer or septic?
      Bubbling out of full tank or buried manhole ?
      Never give up on your dreams..
      dreams are what make us forge ahead.
        I already knew he is connected to the city sewer and he does not have a sewer pump. The yard is on a slight grade from the house down to the street. He has an irrigation system which was still shutdown for the winter.
          #3 does it bubble every time you flush the toilet or run the washing machine?
          sounds like a partial stoppage and he disrupted the pipe and ground around it with that root he cut.
            Well, I didn't ask that question and he already told me he noticed it bubbling after they used the plumbing.
              Did I mention he is a lawyer, with all that entails, and was not apt to be running back and forth to check that.
                Sounds like he cut or "aerated" his sewer line.
                  Most aerators that i have seen don't go deeper than 8" or so. I would be hard pressed to say that he cut the line. How big was the equipment he was using? Big enough to callapse line? At any rate he definately has a collapsed sewer. Be sure to load up the seesnake when you go over.
                    Nope. Not a cut or collapsed sewer. When I drove up to his home I could see before I got out of the truck that my phone diagnosis was probably correct.
                    It's still early, If no one guesses correctly I'll put the answer up late tonight.
                    But for now, I'm back to work.
                      was he wearing rubber boots???lol
                        My top questions wouldve been.
                        Your number 1 question
                        #2 Have you ever had a problem with your sewage system backing up before?
                        #3 Have you lost water pressure in your house?
                        #4 Have you been noticing any backups, or gurgling sounds in your lowest point?
                          Well if he didn't have a cut or damaged sewer liine, then the only thing I can think of that would smell "sewery" is a nicked gas line. I know that's a crazy guess but everything else has been said that I can come up with. Doesn't explain the wetness and bubbling during plumbing use though.
                            Drain medic,
                            To answer your questions as I think he would have:
                            #2. Not in the last 10 yrs.
                            #3. Have not lost water pressure in the house.
                            #4. No gurgling or backups inside the house.
                            JCsPlumbing, Great guess but nope, that wasn't it.
                            I'll give a hint later tonight, I just got in from work and I smell DINNER!!
                              Does the homeowner have a french drain for their wash machine?
                              Proud To Be Union!!
