Self Feed Bits
  • Self Feed Bits
    I am new to this forum, it is great. I am a newer contractor that went out on my own last year. I am now "scabbin for a livin" full time. I need to get some new self feed bits and wonder if anyone has a preferance. I wore out my old Milwaulkee bits to where they can't be sharpened anymore. I have tried the Dewalt and it is fast and sharp but not for long. I heard the new Milwaulkee's are China made and not any good anymore. Any good ones left, or just go cheap?
    Re: Self Feed Bits
    I like lenox one tooth bits. Goes through studs very quickly.
      Re: Self Feed Bits
      milwalkies are good there not gonna last long though ecspecially if your pulling nails with them
      Mike
      www.plumbinginclarkcounty.com
        Re: Self Feed Bits
        lennox by far the best i have ever used. th eprice is steep up front but will last allot longer than millwaulkee , which used to be my top pick
        how is it that so many answers are in the instructions
          Re: Self Feed Bits
          I like the lenox bits. I will use the self feeding bits up to 2 9/16" and the One Tooth Hole saws for the larger holes 2 3/4" on up.
          ________
          Suzuki Satria History
          Mike
            Re: Self Feed Bits
            I wondered how those one tooth bits worked. I will have to try one out. I'll give the Lennox a try, I am not a fan of their hole saws, they wear out 2x quicker than Milwaulkee drilling metal.
              Re: Self Feed Bits
              That's because you're using the wrong kind. I love lenox's carbide sheetmetal bits. I use these for SS and they work great for metal studs.
                Re: Self Feed Bits
                I've got probably 4 5 gallon buckets of self feed bits sitting in the shop rusting away since I discovered the Lennox 1 tooth hole saws. I swear they cut my rough in time by 1/2
                  Re: Self Feed Bits
                  No kidding? You use them even for 2 9/16"? And does the plug get stuck in it and you have to fight to get it out??
                    Re: Self Feed Bits
                    The plug never gets stuck in a Lenox One Tooth. Falls right out.
                      Re: Self Feed Bits
                      http://www.lenoxtools.com/enUS/Produ...feed_Bits.html
                      (Not your average self-feed bits)
                      http://www.lenoxtools.com/enUS/Produ...ILITY_BIT.html
                      (Some good auger bits and especially for electricians)
                      (One tooth hole saws) http://www.lenoxtools.com/enUS/Produ...LE_CUTTER.html
                      I think you'll be happy when you give them a test try.
                      And for serious cutting with a reciprocating saw (Sawzall) please give these a try.
                      http://www.lenoxtools.com/enUS/Product/LENOX_Gold.html
                      Sawing by hand with a hacksaw? Please try some of these out soon.
                      http://www.lenoxtools.com/enUS/Produ...AW_BLADES.html
                      Note: I do not work for or sell LENOX. I just use them and have found most of their products to really work when the going gets tuff.
                      Special note to GearJunkie: Thanks so much for posting about these great tubing cutters. What a nice difference.
                      http://www.lenoxtools.com/enUS/Produ...G_CUTTERS.html
                        Re: Self Feed Bits
                        Been telling people that lenox tools are coming up. Are you coming to the roundup?
                          Re: Self Feed Bits
                          I bet mr. gc would rather clean up plugs than sweep for hours to get up shavings left behind by self-feeders. And i bet they are alot less likely to sling that pine tree into your eyeball when drilling overhead.
                            Re: Self Feed Bits
                            Same here, drastically reduces cleanup time.
                            I'd just like to know how well these one tooth saws handle nails, past experience wasn't good.
                              Re: Self Feed Bits
                              The new lennox saws will hog right through them.
