Taco PC700
  • Taco PC700
    Anyone out there familar with this Taco control?I am wondering which water temp the sensor bulb is suppose to sense supply from the boiler or return?
    Re: Taco PC700
    The sensor should be installed on the supply side, about 18" from the boiler. Make sure to insulate it well. The outdoor sensor should be on the north side of the house, away from direct sunshine or any other heat source.
      Re: Taco PC700
      Would it also work in the well that has the bulb from the Honeywell L8148 control which is basically a Hi Limit control?
        Re: Taco PC700
        yes
