Water heater pics
  • Water heater pics
    This is for a 35 gal electric w/h. The 2 fpt stubouts are for thermometer but waiting on the thermometer wells. I do know the soldering sucks and I'll leave it at that. Tell me what you think, be honest.
    Re: Water heater pics
    Is the valve going to the expansion tank the style with the built in relief valve? It does not appear to be.
    If not, that valve is just a waste of money.
    Is that a mixing valve it looks like?! Can you explain why thats there? Sorta confused by that.
    Proud To Be Union!!
      It looks good ben, I like the idea of the ball valve installed just for the expansion tank, this also helps for isolation purposes.
      I have a silly question, is this residential?
      why the mixing valve, the thermometers?? how hot do you expect a 30 gallon electric to get???
      Robert
        gear not bad, curious though wouldnt you need some check valves to eliminate any potential for crossover?
          Mixing valves don't need checkvalves...I think?
            Is a shutoff legal for TXT?
              Wait a minute, I follow the National Standard Plumbing Code and it's ill-legal to have a valve in between the water heater and the expansion tank. Due to the fact that someone could just shut off the valve, making the expansion tank pointless/useless.
              Proud To Be Union!!
                Didn't think so. But I've learned much from GJ so I thought I'd give benefit of the doubt.
                  You are RIGHT! Wow, this young apprentice is smart. I bet You'll have you license at a very young age!
                    and for the uninitiated amateur in the room, what is the purpose of the apparent connection of hot to cold behind the expansion tank.
                      Thanks boss.
                      JC, I gotcha back dawg.
                      Ben, didn't I tell you to write that down at the gathering?
                      Proud To Be Union!!
                        valves are never a waste of money ,it will make changing the tank a lot easier if it is bad .and you have a relief on the heater
                        if it is i take the handle off and the inspector will pass it
                        ben good job but your stubs for the thermometer's look a little far from the flow of water to get a good temp reading
                          Charlie, I agree and dis agree with your statement. In this instance, the valve is ill-legal.
                          Proud To Be Union!!
                            dont you need unions on your heaters?
                            Mike
                            www.plumbinginclarkcounty.com
                              thats a thermostatic control valve, or a mixer, it maintains a certain water temp, making sure the water doles not get to hot
                              my question is, why all the temp control on an electric water heater?? a 30 gallon, what appears to be a residential
                              boilers or commercial water heaters, yes....
                              help me on this one.....
                              Robert
