Have you tried the Bradford White GX2-25S?
  • Have you tried the Bradford White GX2-25S?
    Has anyone here tried the Bradford White GX2-25s High Performance water heater? I will be replacing the 75 gal. gas a.o.smith that I mentioned in an earlier thread (Troubleshoot this noise).
    I see it has a 155 gallon first hour delivery. Intregal mixing valve. It uses standard 4" type b double wall vent pipe. 1/2" gas connections. 78,000 btu's
    and only a 25 gallon tank.
    When I talked to their support on the phone he said it's output is 5gpm. sounds pretty low to me.
    I know a plumber here who has installed one but it hasn't been in long enough for feedback. You can view the specs here.
    http://www.bradfordwhite.com/images/...heets/115b.pdf
    I don't relish the thought of toting a 75 gal. gas up to the second floor attic.
    Speaking of which, does anyone use one of those PowerMate power stair climbers? Is it worth the outlay?
    Re: Have you tried the Bradford White GX2-25S?
    i have an electric stair climber. used it today on an 80 gallon gas heater. (1986 american gas heater)
    sure made it nice for the upstairs climb. and controllable for the down stairs decent.
    i can do 100 gallon heaters by myself. also a block and tackle and electric winch makes life easy on the back.
    you still need strength to control the load and keep it balanced.
      here is the one i have
      http://www.escalera.com/prices/index.htm
      ms-1-72 1200# capacity.
      rick
