WTF-pics
  • WTF-pics
    Why plumber's have job security. This is the back of a mixing valve.
    Re: WTF-pics
    You can do it, Home Depot can help.
      Re: WTF-pics
      I am raising my prices again
        Re: WTF-pics
        NHMaster3015 has the best sarcasm
        " No we have our furnace professionally cleaned all the time"
        "If you put a drain pan under it I can get away with not changing it out right?"
        " What do you mean that is my water main in my sprinkler box? and I don't see why you can't repair it without removing all my sprinkler stuff... My sprinkler guy came very well recommended...
        If it is too silly to believe I take a picture they are also a little C.Y.A. for me.
          Re: WTF-pics
          what's that furnace, about 75,000 btu's on a 1/2" copper line.?
            Re: WTF-pics
            I was at a house adding a filter in, and came across this.
            Don't worry guys, this is the commerical grade duct tape, it'll be fine.
            I took this whole mess out when I replaced the water heater.
            Proud To Be Union!!
              Re: WTF-pics
              Great pics guys. We should keep it going.
                Re: WTF-pics
                NHMaster3015, yep that is very common for this area.. It ends up that the copper was the demise of the gas valve. The owner was in closet and banged on the copper a few times knocking the black crust loose into the gas valve... I ended up replacing the gas valve and about 6' of copper (all) for iron.
                75K btu input maybe 40 output...
                  Re: WTF-pics
                  Tile floor was raised - tile guy did his own plumbing. Told the homeowner it wasn't brain surgery. I think he needed some brain surgery. It lasted a little while.
                    Re: WTF-pics
                    Customer called that she had a leak under her sink...
                    The broken stub-out was repaired with calk and duct tape at some point in the past
                      Re: WTF-pics
                      What was the reason for your service call?
                      Stink or leak?
                        Re: WTF-pics
                        Only the gas company is allowed to do that kind of work in our area.
                          Re: WTF-pics
                          Aaron, is that rubber cement or jizm on those pvc joints
                            Re: WTF-pics
                            Stink or leak?
                            It started leaking into the downstairs condo off and on because that toilet wasn't used much. Then the flapper hung up and it leaked A LOT into the downstairs condo. The downstairs owner was away and the ceiling fell.
                            These are some real pricey condos overlooking the Mississippi river.
                              Re: WTF-pics
                              looks like cpvc cement
