Roundup requests
  • Roundup requests
    Some things I'd like to do at the roundup, equipment demo-wise... thought I'd post here as others might have things to add...
    - run a few sectionals, as I never have done, in as close to real world scenarios as possible.... Josh? could you start flushing paper towels and children's toys in your building so the lines are well prepped for us? Really though, can we clean some lines in the building? I think it would be a better demo for me than events set up in exposed pipe.
    - particularly would like to run Ridgid's bigger sectional in a 4" or 6" line half filled with typically poorly set up concrete, and or a root scenario at a longish distance. The prophesied wood cutting event may suffice for this. I'd like to compare with the 3/4" drum machine I use for these now.
    - preview any upcoming camera technology as I am unhappy with the vcr tech in my current cameras. And pick the brains of whoever is your most knowledgeable camera technician on my other issues.
    - use the full size see snake as I have only mini's and might want the bigger pushrod after using it.
    I'm sure there are other things, but other than meeting some of those I've talked with here and having some fun, those are my major goals for the trip.
    Re: Roundup requests
    ace, i was a little bummed too that there is no heads up k-60/ 7500 battle to the death
    i will be happy to run you through the k-60/1500 demo.
    the wood cutting is more of a prop to show how fast a 1500 can drill a hole in the pine board. it's not safe or set up for a drum as the board is only a couple feet away and the spinning drum will pose a hazard.
    you'll like the push of the full size seesnake and the brighter lighting
      Maybe that is super-secret-hush-hush-#8
      I love my plumber
      "My Hero"
      Welcome, Phoebe Jacqueline!
        I like my mini because it is light and fast but you are limityed to how far you can push it. For the bigger\loner stuff the self-leveling comes out.
          If there isn't, that is probably a good thing. That debate will never end, and a battle will only fuel it and result in a lot of acrimony. While some machines are better for some things, most can be made to work for most things, and I suspect (from my admittedly limited vantage point, having NEVER run a sectional, that it comes down to personal preference most of the time, possibly to how often you see the situation a particular machine really shines in. I'm just interested in in trying what I haven't yet and seeing how I like it.
            I think we could accommodate your requests. Setting up the scenarios may not be possible but I will see what we can do.
            Josh
              Josh
              Free drain cleaning for Ridge tool employees? They can do a contest to see who wins free drain cleaning at their house
              I love my plumber
              "My Hero"
                this is a good one to see who can make the biggest clogged drain
                  I`m thinking a 8lb shot-put would put a kill on a K-60
                    Josh
                    Start now, get some corrugated pipe with one end exposed and plant a tree nearby, Pour some fertilizer water in there and let the roots grow. At the roundup, dig up the pipe, attach a pipe on both ends and away you go. Or what if you get a pipe with a test tee in the middle and push a tree roots in there?
                      I heard of a guy that did the cleanout thing recently,Can't remember why.
                        My way has to be easier All those employees, chances are a good % ALREADY have sewers with stoppages just waiting to happen
                        I love my plumber
                        "My Hero"
                          Josh, maybe you can get the cafeteria to do "all the free tacos you can eat" for the entire week beforehand!
                          I'll gladly contribute to the cloggering!
                          Steve
                          www.MorrisGarage.com
