Advice -Pex tubing
  • Advice -Pex tubing
    I am researching a boiler/water heater combo that heats water
    for shower sink etc and also heats and pumps water through a radiant
    floor heating system. I would like to avoid baseboard units in the
    basement (existing slab-unfinished basement). Has anyone heard of laying down treated sleepers on the slab,
    running the PEX tubing in the bays and installing plywood over that? Is
    there a way to heat the basement with this radiant system of tubing and
    fins without the exposed fixtures?
    I found the supplies on Houseneeds.com and they have a really good deal. I just wanted to make sure that this was the best solution to my problem. Any advice is greatly appreciated!
    Re: Advice -Pex tubing
    I would ask this question in ask the plumbing experts area
    but I will give you my 2 cents here...
    "I am researching a boiler/water heater combo that heats water
    floor heating system ( Piece of equipment needs to have dual heat exchangers since heating water and potable water cant mix). I would like to avoid baseboard units in the
    running the PEX tubing in the bays and installing plywood over that? (Bad idea since this defeats the purpose of radiant heating, you would be effectively insulating your heat source from the space) Is
    there a way to heat the basement with this radiant system of tubing and ( If you have the hot water you could use a simple fan coil unit that could be placed inside a wall or hidden )
    Do yourself a favor and contact licensed professionals ( Plumber and or HVAC) in your area and discuss your ideas.
      Why does this post reek of spam?
        UMMMMM, Cuz it is?
          It doesn't look like spam to me. Just needs to be moved to Ask the Plumbing Experts or HVAC discussion
            Check both her posts she is just plugging that site
              There is a system out there that you lay down precut grooves and lay your pex in that. It's expensive and time consuming. We've done it for the people here that are selling it. I would also suggest staying away from the combi-core water heaters. They keep coming out with new models that fix old problems, but they haven't had one on the market long enough to prove it yet. Some places won't let you use a water heater for that either, believe it or not, even if that's the only purpose you use the heater for! Check the local pro's
                Spam spam spam spam spamity spam
                  Hi OkieBill,
                  Thanks for sharing that deatiled info on Pex tubing. It helped me take a decision on the same. Contacted a few professionals and got their feedback. Thanks once again !
                    ok... looks like i was wrong not spam.............. ill go back in my corner now
                      I deleted them thinking it was spam at first as well. It may be. Sorry if your not a spambot Sandy. Lotsa creative spamming happening now.
                        Hi wrench spinner
                        I know ur not a spammer.. Thanks for that info.. But you can check this site HouseNeeds.com.. Its got some info related to pex tubing..
                          Crud is spam...
                            *** Good Forum Members please ignore this little rant of mine***
                            I will be more than happy to dig out personal email addresses and names associated with this entity if this behavior continues Mr or Ms Spammer.
                            I nor my company will ever buy a product or service from your disassociated attempt at an internet sales business.
                            Here is the information on the company that Hosts your site Spammer:
                            OrgName: Hosting.com, Inc.
                            OrgID: HOSTI-8
                            Address: 501 S. 4th Street
                            Address: Suite 300
                            City: Louisville
                            StateProv: KY
                            PostalCode: 40202
                            Country: USA
                            OrgAbuseHandle: ABUSE733-ARIN
                            OrgAbuseName: ABUSE-ARIN
                            OrgAbusePhone: +1-502-515-1592
                            OrgAbuseEmail: abuse@hosting.com
                            Registrant:
                            HouseNeeds.COM
                            POB 178
                            Waitsfield, VT 05673
                            US
                            802-583-2726
                            Domain Name: HOUSENEEDS.COM
                            Administrative Contact:
                            Lepp, Branwell blepp@houseneeds.com
                            POB 178
                            US
                            802-583-2726
                            Technical Contact:
                            POB 178
                            US
                            802-583-2726
                            Record last updated 07-17-2002 09:20:43 AM
                            Record expires on 03-31-2013
                            Record created on 03-31-1999
