Pex Mess...
  • Pex Mess...
    Ran across this today. Everyone can't or shouldn't do their own plumbing!
    Re: Pex Mess...
    I have seen even worse, it looked like a bowl of spaghetti, and red and blue were tied together everywhere. Supposedly a pro plumber did it, I told the GC I wouldn't touch it without redoing it all completely and I ended up walking away from it.
      Re: Pex Mess...
      Good looking stuff there
      I especially like the water heater sitting on dirt behind the cast iron drain.
      Going to be some cussing when you get the call to change it
        Re: Pex Mess...
        From the looks of the rust staring on the side it looks like it may be about that time to change the heater too!
          Re: Pex Mess...
          For fun, name the things that aren't up to code in the W/H picture.
          Hocus Focus for plumbers.
            Re: Pex Mess...
            Hmmm, lets see. Shutoff valve, expansion tank, conduit, backflow preventer on the drain, probably T & P line, what else am I missing? Nice dryer vent by the way. Have fun changing the heater when you do.
              Re: Pex Mess...
              You need to have a minimum access to the WH of 20"x30". Don't think I've ever seen a crawl space with big of a door.
                Re: Pex Mess...
                The dry rot on the flooring above is a good example of why they usually put plastic down over dirt. Looks like they had some used lumber when they put in the subfloor.
                  Re: Pex Mess...
                  Perhaps it would be easier to note what was done correctly. I had my eyes dilated earlier today but through my squinting eyes none of it looks legal.
                    Re: Pex Mess...
                    I see 4 more that haven't been mentioned. At least how things are enforced in my area. Don't want to be an a$$ so I'll tell the easy one.
                    1)Improper support on distribution piping.
                    The other 3????
                    (Plumbing only. I'm dumb as wood at about wood, electric, or HVAC. Some might even say plumbing!)
                      Re: Pex Mess...
                      No drip pan under tank. I'll let the other guys get the other two.
                        Re: Pex Mess...
                        They don't enforce a drip pan under the tank in crawlspaces here. But they might start soon. And one of the things I noticed they might not enforce where you are. I'll list it if noone gets it soon. At least the ones I see.
                          Re: Pex Mess...
                          I'm sure it must be the camera angle, but this looks like a violation of the first rule of plumbing!
                          I've seen a lot of crazy things like this over the years. It never fails to amuse me.
                            Re: Pex Mess...
                            No. "IT" does run downhill!
                              Re: Pex Mess...
                              it isnt plumbing but there should be an electrical shutoff within eyesight of the unit be it knife switch or circuit breaker they may be behind you but based on the camera angle it isnt
                              no vacuum breaker on the unit
                              and most of the other things i can see wher pointed out in earlier posts
