pvc pipe puller
    Re: pvc pipe puller
    good idea thats what i have done on my last job because i had to do some my self
    i still would like to see the puller work
    thanks charlie
      Re: pvc pipe puller
      Originally posted by HVAC HAWK View Post
      this is it they are showing hub pipe but it can be used on glue
      pat #ppjfa
      You could make this pretty easily. All you need are 2 pipe vises with a I beam clamp.
        Re: pvc pipe puller
        concept team in progress
          Re: pvc pipe puller
          duck all the pipe is in the ceiling
          I got one word for ya....Ibuprofen.
          Originally posted by stokefire7 View Post
          what about a couple riser clamps and some 1" black, couple pieces of chain ?
          That sounds suspiciously similar to a cumalong and two friction clamps....
          Keep one friction clamp loose...then grab it tight with channel locks as soon as you're ready to work the cumalong, hold the channel locks tight until the solvent weld sets....then let go of the channel locks.
          You could even do this alone once you get the hang of it.
            Re: pvc pipe puller
            i have a small cumalong that can be used as a chain hoist by pulling on the chain until it gets tight then use the cumalong the rest of the way
            thanks for the help
