Flush valve more than 4 3/4" from center
  • Flush valve more than 4 3/4" from center
    Ive seen extensions for flush valves before but i cant find them online anywhere. Even the sloan website mentions nothing about them. I need some help. Thanks
    Re: Flush valve more than 4 3/4" from center
    My supply house can get them for me overnight.Perhaps yours can do the same.
      It's been a while but I think you can get them in 1" increments up to 4"
      The real trick is getting the factory one out without scratching the body
      Wrap it in a towel, put it in a 3 legged vice
        so true sloan makes an internal nipple wrench. but it is still a little pain in the as# to remove
          We call them "goof nipples"...
          (as in you goofed roughing it in....)
            there is an internal wrench that is made,
            but if memory serves me right
            the handle from a 10'' or 12'' pipe wrench fits in there too
            shouldn't be an issue locating longer tail pieces as they were a fairly common part. are you sure sloan doesn't have them how about zurn?
              The tool is called a radiator spud, I think. It's a telescopic socket type tool with different sizes for different applications. The one I have I cut to exactly fit a Sloan nipple. If the factory robots wouldn't tighten the nipples so hard, it wouldn't be an issue.
                There's a trick you know...
                Put the handle from a Hole Hawg (the pipe screw in handle) into the bottom of the flushometer (or a pipe, although the handle is handier) and have someone hold it securely, place the handle of a ridgid (they must love the free advertising) adjustable hex wrench into the nipple..it just happens to fit perfectly (coincidence..I think not!) and using another pipe wrench on the spud wrench, unscrew the nipple.
                This is the ridgid wrench...
                http://www.ridgid.com/Tools/Hex-Wrench/EN/index.htm
                Works every time!
                The nipple extensions are listed in the Sloan catalog, can't imagine why you can't find them. ALL our local supply houses carry different sizes...do you have a Ferguson near you??
                Douglas
                  Works every time!
                  Douglas
                  douglas, welcome to the forum.
                  nice to have another thinking plumber on the forum
                    Douglas, welcome to the forum!!
                    Robert
                      When the r/i's miss on those we have gotten by with an offset Vacuum breaker on urinals.
                        Here guys, this is all the info you need for this in the future...
                        http://www.sloanvalve.com/maintenanc...16505Rev0a.pdf
                        Just print this out and keep it in your Sloan repair book.
                        Douglas
