Pool heater help
    Re: Pool heater help
    Originally posted by HVAC HAWK View Post
    this is a bypass on a boiler
    the valve in the middle is to adjust it so your not having 100% cold water going back into the boiler .this will keep the coil from condensing
    Thank you. We install them all the time on our boilers. On a different note I was scanning through the manual from the link NH Master posted, as far as the by-pass, it's not necessary unless filtration rate exceeds 125 g.p.m. That is as per Teledyne-Laars manual for an LLD-250N.
    I spoke with the homeowner today and I will most likely return there Saturday to check the condition of the coil. Unit is 10 y.o. and the owner does not want to sink too much labor or material into this unit so he is thinking of replacing it if the coil is clean on the outside. I will keep you guys updated. Thanks for the help again.
      Teledyne manufactures those boilers in my town.
        and you have to wait a week to get parts to
