Boring under sidewalks?
    Re: Boring under sidewalks?
    Originally posted by spodelee View Post
    Wow, what a great resource! Have any of you used their sweat plugs?
    http://www.perfectoproducts.net/inde...age=sure-sweat
    Garbage, like Gear Junkie said, BREAD. Or be a real man and take the plunge and buy a Propress system. Impress your customers on your ability to put in a fitting with water gushing out of the line, and then watch them pay you more because your on the cutting edge of the business!
      I have to admit, unlike a lot of you plumbers out there we don't get into the "run it under the sidewalk/driveway" Very often.
      However on the rare occassion that we have to, "Usually some BRO deal were doing for someone we fabricated our own system.
      a: Pressure washer Jerry Rigged to fit on one end of a copper pipe.
      b: Copper pipe other ended fitted with some type of sprayer.
      c: Extract all the crud that comes out with a Crusader Wet/Pump Vac.
      http://www.crusadermfg.com/vacuums.c...ID=38&P_ID=543
        A piece of 2" galvanized and smack it under with a sledge hammer or push it in with the excavator all done in 15 mins pull the pipe out on the other side leaves a nice round hole. Shove the 3/4" K thought the hole an its over with out wrecking the place. Having the machine push it through is the fastest. If its a long run shoot the bullet and remove the nose when it sticks out of the side of the trench, hook the copper to the head with a pulling basket and put the bullet in reverse and it gets pulled back through the hole.
        WE LIVE IN THE LAND OF THE FREE,
        ONLY BECAUSE OF THE BRAVE
          Now I REALLY want a tractor of my own!
          spodelee
          Until lions have their own storytellers, stories of the hunt shall always glorify the hunter
            We use to do 40-60 foot water mains under driveways with the Hydro-Drill all the tine. It is a great little tool.
            How hard is it to direct the bit so you don't miss the destination?
              You set it up with a level and a good eye, turn it on an hope for the best. We have missed a few times. Had it come up in the street once all it needs is a big rock to send it off. About 95 % of the time it comes out right in the trench.
                A mini excavator with rubber tracks and a hydraulic thumb is the ticket. The differance between men an boys are the price of the toys.
                • #23
                  Yeah, we've done stuff like that. But the backhoe might be here or there and we might be in a hand dug trench somewhere else. Appreciate the input though.
