Dishwasher not next to the sink
  • Dishwasher not next to the sink
    Have a question for you guys.
    I am doing a remodel and the dishwasher is not going to be next to the sink and going to be about 7' away.
    The dishwasher is my farthest run from the main.
    Question, what is the best way to plumb this drain in. I fall under UPC code.
    Do you run a stack next to the dishwasher in a cabinet?
    Also, is there a need to trap it, due to the dishwasher already being trapped?
    The closest vent is at the kitchen sink, 2".
    I have presented this question to a few local plumbers and get mixed answers. Just want to know how you guys would do it.
    Thank you in advance,
    Ty
    Re: Dishwasher not next to the sink
    In Illinois, we can extend the d.w. drain hose and run it thru the cabinets.
      Our code would call for it to have it's own vented trap, with a two inch vent being more than sufficient.
        Is it in a bank of cabinets which connect to a sink cabinet? If so, run it through the back of each one until you reach the sink cabinet. If not you can run it in copper below the floor (assuming it's a crawlspace). There's nothing in UPC (any addition) that contradicts the above.
          Run it to the garbage disposal.
            That's a code violation in Illinois.
              I'm with Plumbus. Through the floor if it's easier than through the cabinets.
              I built my own cabinets, so was able to run through them as part of the design. I have always used 5/8" heater hose, now dishwasher hose that's identical.
                Never would've believed it. Any reason why?
                  Hot water should never be used in a garbage disposal, it even tells you that in the owners manual.
                    UPC will let you either extend the hose through the cabinets and connect as usual under the kitchen sink. (don't forget the vaccuum breaker) or run it to a trap beneath the floor. (don"t forget the vaccuum breaker)
                      I think the manuals state to not use hot water while USING the garbage disposal.
                        Perfect situation for a flood. Too many times, food is put into the disposal, and not ground up. Dishwasher runs, drains...water all over!
                          It is on a crawl space so, I think I will trap it below the floor. Just wondering how some of you guys do it.
                            Everyone here runs it to the garbage disposal. I learned something new from you guys. Thanks.
                              If you can't run it through the disposal, why do they provide a 3/4" waste inlet at the top of disposals?
