The wall of fame ,the wall of shame
  • #46
    Re: The wall of fame ,the wall of shame
    Condensate?
    Or T+P
    Condensate.
    • #47
      1-1/4" threaded y-branch tailpiece would have come in handy.
      • #48
        Yes but that was the whole problem. When the santee was roughed in it was to high to install a branch tailpiece in finish. That is why the condensate was hooked up to the trap arm instead of the tailpiece. I can understand doing this once but this project was full of them.
        • #49
          Originally posted by glkearns View Post
          Have to say, that is the first time I have seen radiator hose used like that. How many different types of material is there? Looks like ABS, PVC tubular and is that a corroded metal tailpiece going into the PVC E-Out waste?
          Eew.
          Greg
          jesus christ!!
          • #50
            Love this thread
            • #51
ID:	616247 Click image for larger version
ID:	616248 Click image for larger version
              All pics are from the same house
              Pic #1 Toilet flange elevated by bricks because the main sewer is just a few inches below slab. Good thing they make a 20" poly closet supply
              Pic #2 Looking down into a vanity cabinet with the top removed. The 1-1/2 line coming through the side of the cabinet is from the washing machine. Customer said her sink gurgled when the laundry was draining
              Pic #3 Wants me to fix the leak on the water heater at no charge because we put it in 3 years ago
              • #52
                WHEN YOU DID THE WATER HEATER INSTALL
                "WHY" THE GATE VALVE UNDER THE T&P VALVE ? ? ?
                JERRYMAC
                E-MAILJERRYMAC777@GMAIL.COM
                FIRE SPRINKLER CONTRACTOR,
                SINCE JAN. 1989
                • #53
                  Good eye jerry, that is a major code violation.
                  • #54
                    You didn't really install that did you?
                    • #55
                      that was a joke about 3 years old and you did it ----right????
                      homeowner must have put that gate on after u left
                      • #56
                        I proudly admit that I did install that heater
                        Look closer gentlemen....thats a boiler drain NOT a gate valve
                        If it were a gate, the relief valve probe would keep it from shutting off
                        • #57
                          crack, i was originally thrown off when they jumped on the band wagon.
                          guys take a closer look.
                          it's a brass tee with a boiler drain screwed into it.
                          remember bill is on team geritol
                          not team juvenile
                          • #58
                            I saw that right away also,thought it was My big moment, to bust a real plumber! RATZ
                            • #59
                              CRACKS (NOT Dunbars -edited) cred..saved.
                              But, whadaya need a drawoff for at the top of a heater below a T&P?
                              • #60
                                GOOD CALL "RICK" I MISSED THAT,
                                NEVER SAY I AM NOT ONE
                                TO ADMIT TO MY MISTAKES
                                THAT TEE WITH THE RISER STILL LIFTS THE
                                PROBE OUT OF THE HOT WATER AT TOP OF TANK ! ! !
                                AND WHY A BOILER DRAIN AT THE T&P OPENING
                                IS THAT LOCAL CODE OR SOMETHING ? ?
                                JERRYMAC
                                SINCE JAN. 1989
