R.O. Drain Connection
  • R.O. Drain Connection
    Everytime I install a R.O. system the send the 3/8" discharge line to be connected to a saddle valve on the drain.
    I do not like this type of connection. Is there another part or way of doing a neat clean job without using a saddle valve for the drain?
    Re: R.O. Drain Connection
    D/W drain branch. You have to adapt to it, no biggy.
      The last r.o system I installed had an adapter that fit into a continuse waste tee and was a 3/8" push in connection. The owner supplied it so I'm sure it came from home depot.
        Thanks guys!
