Vent Tee installed upside down
  • Vent Tee installed upside down
    My boss wants me to prove to him, in code, that vent tee's are supposed to be put in upside down like the scanned picture shows.
    I cannot find anything other than 905.2 which states,
    "All vent and branch vent pipes shall be so graded and connected as to drain back to the drainage pipe by gravity."
    Here is a pic.
    Re: Vent Tee installed upside down
    That is a san tee upside down, a vent tee has no sweep.
      I read something like that in my code-book and thats the way I was taught to do it.
      I am too lazy to look it up right now, but you are right Tyman.
        This is my interpration of that section. The smoothest way for air to go down that line is if the tee is upside down. Another problem I have with the ipc is that it doesn't mention prohibted connections for venting. I fought with a civil engineer for almost 30 because he told us to use a saddle tee on a CI stack for a vent connection that would be behind a consealed wall. Billy bootcamp won because I couldn't find a specific reference in the ipc that prohibits that installation.
          Noted, is it correct then? If so, do you know the code number.
            the fittings have to be installed in the direction of flow.
            since this is a vent, the flow direction is up to the roof.
            the photo in the book is correct and your boss is wrong
            see if the 3104. 2 irc or 905.1 of the upc will apply.
              There is nothing in the IPC or the UPC about it and if you think about it for a minute, air doesn't give a rat's butt whether or not the fitting is upside down or not.
                His argument is, that when snaking from the vent on the roof, your snake will be more suceptible to following the branch if the tee is install like that.
                  We don't share the same code.
                  a vent tee looks like this.
                    Here is a pic.
                    Nothing at all isn't clear in that wording, not to me at least.
                    Vents being connected to drain back is for rain, condensate and the occasional twig & dead critter to find it's way back to the main.
                      ...and that too.
                        Another reason why I put them upside down is because its easier to identify a vent (in case it's in a tight spot or something and it's hard to confirm if a pipe is a vent or a drain). Most of the time, if the pipe was a drain, there would be a wye fitting there, but the way some places are plumbed, you never know
                        YourHomeContractor.com - The Trusted Online Community For Homeowners and Contractors.
                        Plumbing Reviews
                          THIS WILL GET BATTED AROUND FOR AT LEAST 40 POSTS. I believe both are acceptable
                          Why is it labeled a vent tee,If it can't be used in that attitude? Ohh well I'm just a dumb Carpenter stirrin the RIDGID POT.
                            I don't know why that is labeled a vent tee. A vent tee is a tee without any sweep. Weird. I didn't notice that in the picture the first time around.
                            Plumbing Reviews
                              Simple..."stink up, poop down, dont bite your nails on break, payday is on Friday." Around here they say it helps the "stink" go up.
