Copper getting thinner?
  • Copper getting thinner?
    Changed out a 21 year old AO smith WH yesterday. I noticed the type L that I pulled out was visibly thicker than the type L that I reinstalled. Has anyone else seen this decline?
    Re: Copper getting thinner?
    Yes
      Yes. Mentioned it to the supplier. They said they don't doubt it but what do you do. Glad you mentioned it....thought I might be losing it.
        Well, my hairs getting thinner. My wallets getting thinner. Why not copper? Hell it's on the way out anyway. Pexify the world, wrap it in plastic
          I hate pex
            Sorry but you guys are just imagining the difference in wall thickness. The letter designation is based on an ASTM Standard which lists the thickness. If the tubing is a different thickness it would have to use a letter other than those already assigned.
              so that means that K copper is now L
              L copper is now M
              M copper is now DWV
              and DWV does not exist
                copper tubing, i don't have an issue with.
                it's the fittings that are short radius and thinner.
                another good reason to go propress.
                long radius 90's and type k fittings.
                  I thought so too Mark so I weighed a 12" section of the new and old pipe. Old pipe 6 3/4 oz. New pipe 6 1/2 oz. I think we're going the way of the lumber industry.
                    If that is true then the piece of tubing you just installed is illegal. The ASTM Standard has a slight +/- but if every piece you install is too thin you have a bad batch of pipe which should have never made it to the supply house.
                      Just walked to the truck because you got me thinking. I got 5 sticks from ferguson's yesterday and I used 1 stick. I checked the 12" cutoff from the original compared to the other 4 remaining sticks and they all had the same thickness. It wouldn't suprise me if fergusons sold the cheap stuff now.
                      Question Mark. If a plumber installed type L pipe as per prints but it failed prematurely, and it was found not to actually be type L thickness, but was labeled as type L, who is at fault?
                        The manufacturer, the distributor, the supply house, the plumber and the builder could all be held responsible.
                          Not imagination. Who enforces the ASTM Standard in manufacturing facilities? Unless someone is calipering/weighing etc. right on the line and there independent of the company, you can trust that they will start to shave material.
                            ben, when you said "old" did you mean unused old stock?
                            can you possibly weigh a full 20' / 10' section of old stock. and new stock.
                            make sure that you stand it vertical and support it to keep it from falling over. not to take the weight off.
                            do you have access to a certified scale like used in a market?
                            i guess we could always do like the fishing boats.
                            ben, i need you to make a balance beam and suspend both sections from an equally spaced balance beam. do you have a 18' a frame ladder
                              M seems the same. Don't work with K enough to honestly recognize change. But L appears to be thinner/lighter.
