Gremlins are at it Again
  • Gremlins are at it Again
    Looks like somebody else might have benefited from the service of a licensed plumber:
    Phoenix Explosion
    Re: Gremlins are at it Again
    These stories are ever so common, when will they learn?
      obviously never.
        you mean i have to put the TP valve on it
        but they leak all the time
          YES HE HAD A T&P VALVE;
          BUT PROBABLY PUT A PIPE PLUG IN TO STOP FROM LEAKING ON THE GARAGE FLOOR
          JERRYMAC
          E-MAILJERRYMAC777@GMAIL.COM
          FIRE SPRINKLER CONTRACTOR,
          SINCE JAN. 1989
            T&P valve probably plugged with buildup, and it never got exercised>>>>>>>>>>>>>>>>>>>>>>>
            I saw this where the boilers ended up on the other side of the parking lot, along with most of the blocks from the wall. Also saw one on a W/H (30+ years old) where the srv didn't blow, but luckily the plastic bypass stem on the water softener did.
            Flooded the basement, but didn't turn into a rocket. That house was torn down a year later.
              Master plumb, I love that picture ! We may have a few differences , but We're lock step
              About Those Two!
                Seemed like the homeowner was confident that his insurance was going to buy him new everything. Guess an autopsy of the water heater will be needed.
                  The PBIZ newsletter linked to another story about it. There seem to be a lot of stupid newspeople who can't get their story straight. There's a short video on the page and the consensus seems to be that there was a gas leak. But at the beginning of the story we find: "A water heater that apparently had its pressure valve shut exploded," leading one to believe that it wasn't a gas problem at all. One now has to wonder just how that pressure valve got "shut."
                  AZCentral story
                    Says it all:
                    "It appeared that the homeowner and the man renting the house had been trying to fix the water heater, which may have contributed to the heater being launched across Thunderbird Road and landing near a bus stop, Phoenix Fire Captain Sam Richardson said. "
                      And I get screamed at for refusing to give advice to people who install or repair their own water heaters...this is why, Navysuit and all you DIYers.
                        Originally posted by DuckButter View Post
                        Says it all:
                        MAMA SAY'S STUPID IS AS STUPID DOE'S
                        FOREST GUMP ! ! !
                        JERRYMAC
                        SINCE JAN. 1989
                          AZCentral story
                          The original story had the heater as an electric heater.
                          SRV leaked, you KNOW they plugged it. Some places have checks built in to their water meters. I found out today after mentioning this article that one municipality around here has checks built in, another plumber found out after replacing a relief valve a few times.
                            All the newer meters here have them here which is why thermal expansion tanks are required on all water heaters if they are supplied my city water.
                              On this link you can see a slideshow of the house.
