torpedo?
  • torpedo?
    i have heard of a method in which plumbers use a machine to "torpedo" a pipe underground without having to dig a trench. I need to run a pipe underground from the front of my house across the street, into the ravine (to relieve ground water pressure building around my house). Without getting into the legality of it I would like some questions answered:
    1. What is the real term? Is it Torpedo? Can anybody rent this tool?
    2. How far can it torpedo? I need to go at least 40 feet to the other side
    3. The hydro lines are in the air; the gas line is 5 feet from the surface; the water main is 7 feet down. Is there anything else like the storm or sewage drains that could be hit if i torpedo starting 11 feet down?
    Re: torpedo?
    there are a number of ways to bore a hole 40'.
    i own a few different machines that will do it.
    the problem is, i would never attempt to run any of my machines accross a public right of way.
    what size hole / pipe are you trying to run?
    honestly contract out with a horizontal boring company and see if they will take on this job.
    11' deep is not a simple do it yourself type of job
    so i guess i'm guilty of not helping the o.p.
      Re: torpedo?
      directional boring may help you
        Re: torpedo?
        I doubt that you can rent the machine for one and before any trenching is done horizontally or vertacally the dig safe people need to come out first.
          Re: torpedo?
          THe tool is called a bullet. It is not a DIY toy. Eleven feet in the ground require trench boxes and special training. Call yourself a licensed and insured plumbing contractor and excavation contractor too do the job. Shooting a road requires a permit and a street bond. Now add utilities and your stirring up a can of whoopass that YOU DO NOT WANT TO OPEN. Call a professional.
          WE LIVE IN THE LAND OF THE FREE,
          ONLY BECAUSE OF THE BRAVE
            Re: torpedos sinks nice little home
            If You encroach on a county road ,or others property You'll regret the day You did it!
              Re: torpedo?
              That's not a torpedo! THIS is a torpedo: http://en.wikipedia.org/wiki/Mark_48_torpedo
                Re: torpedo?
                I say go for it!! Seriously, these other plumbers are such killjoys with all this road permit and utility locates stuff. Gosh all Friday you've got just as good a chance of NOT hitting a gas main or fiber optics trunk line. What's the worst thing that could happen. Better to regret something you've done than something you didn't do.
                  Re: torpedo?
                  I've been on a few jobsites that used this device. All of them were less than a 15ft run. The most recent one was 3 feet down and ran under a brick paver sidewalk from a pull box to the road to install traffic loop detectors. The other was approximately 12 feet down (they used trench boxes) to run 8 electrical conduits between a 54 inch storm sewer and 30 inch sanitary line. There's a lot of utilities that could be hit. Most private utilities are near the surface (approx 30") but can be deeper. If you hit a fiber optic line, you better take out a second mortgage on your home to pay that bill. The per hour fees for repair and down time are very expensive. Any work within public right of way will need a permit and that would require a license. I've been on enough construction sites that had gas lines, communication lines, sewers mis-marked or not marked at all that I would never attempt it. It's not worth the price you'll pay if something goes wrong. Hire a professional.
                    Re: torpedo?
                    ALL OF THE ABOVE ;
                    BUT DON'T FORGET THE CRIMINAL PENALTIES,
                    FOR NOT USING LOCATE SERVICES, PLUS FOR DAMAGING UTILITIES,
                    THESE ARE VERY REAL COSTS
                    JERRYMAC
                    E-MAILJERRYMAC777@GMAIL.COM
                    FIRE SPRINKLER CONTRACTOR,
                    SINCE JAN. 1989
                      Re: torpedo?
                      Over on the 'Ask the Plumbers', I'm sure you meant this statement for the "Instructions" thread.
