A pro-pressed this mess?
  • A pro-pressed this mess?
    It is a real shame that idiots can buy good tools. I opened a floor to find this mess done by another licensed plumber that charged rather steeply for the job. The PVC is terminated in the floor left open.
    WE LIVE IN THE LAND OF THE FREE,
    ONLY BECAUSE OF THE BRAVE
    Re: A pro-pressed this mess?
    What was the copper supplying????--what was problem???
      Gotta' admit, I can't tell what the heck is going on. Plus, no support anywhere.
        Its suppose to be a 2" shower and 1 1/2" lavatory back to back. It was leaking on final air test. He got over 4K for this crap.
          Robbery. Didn't know the ProPress could shoot bullets. And why is the broken wye in there? Hope they pursue their money.
            Money can't buy craftsmanship.
              it looks like the lines are crimped off in the second photo.
              also those are not viega fittings.
              i think they are elkhart?
                they are not viega--thats 4 sure--also did u crimp the copper over, or is this pic as is-b4 u touched---anyone can buy a press, u just have to know when and how 2 use it
                looks like that guys a
                  Am I seeing things or are some of the fittings "back soldered?"
                    You know what, I don't need to analyze it anymore. It's just an undecipherable mess. Cut, cut, cut.
                      Its getting sawzall surgery tomorrow. How close can I solder to these press fittings? Have only about 3" from fittings to new ball valves.
                        ALL done be a NY MASTER , Not impressed! Framing looks like a 12 year old did it!
                        Toe nails in 1 1/2", NO hangers ! OSB against Masonry ?? HACKS !!!
                          if u heat those press orings too hot, they will leak--i never tried soldering that close to a ppress fitting--its easier for me 2 walk in with a bucket of pp fittings, the press and some cutters--u may be alright if u wrap the pp fitts with wet towels--i wouldnt try from 3 inches unless u solder quick and cool
                            Funny, when I complained about guys using orings to seal copper with the pro press I was told it'll seal without the oring. No answer when I asked why use the oring then
                              Hey, does any youse guys see a leak? No, so shadduppa you mouth.
