Which Shower Pan to Replace?
  • Which Shower Pan to Replace?
    A while back I was doing a leak search in a Catholic girls college dormatory. {insert Catholic girl jokes here}
    2nd floor bathroom has 6 tiled shower stalls, each used every day but mostly in the morning between 7am and 9am. Leaks into the commercial kitchen and dining area below. I suspect a leaking shower pan but the Head Mistress won't let me cut a hole in the historical tin cieling. I plugged the drains and filled each stall to leave overnight. The next day the trash can I set under the leak was full of black water
    Which shower pan needed to be replaced?
    Re: Which Shower Pan to Replace?
    The one without water in it.
      Were they individual stalls or a "gang" shower?
        individual
          Who said the shower was leaking, and not something else?
          It has rained here recently.
          Proud To Be Union!!
            This job has been over for months. No more leaks from showers
            Did I not mention this was a quiz?
              Based on the information given, I'm sticking to my answer.
                The next day they all still had water in them
                  That helps. So far you got me. Why would you replace a shower pan that holds a water test?
                    hint: why was the water black?
                      I think I might be clueless on this one. I can't think of why a shower pan that holds water would have to be replaced.
                      Or why the water is black. Galvanized butter.
                      Be good to learn what you learned though.
                        I have no idea what 'galvanized butter' is so you need to clue me in on that JC
                        For some reason my wife is online now, she might know the answer so I'll tell you before she gets it and makes you all look bad
                        I filled them with water then added a different food color to each hoping that if the water came through blue, or red or whatever I'd know right away which one was leaking.
                        They all leaked so the water that was in the trash can was black
                        Yea it was a lame quiz, I know
                          That was not good for me.
                          I call the black deterioration and waste in galvanized DWV "Galvanized Butter."
                          You're still alright though.
                            Staining of grout lines obviously weren't an issue.
                            Uh...Yeah Bill,That was out there.
                            Tell your sweety hi for me.
                              It was the stall with the river birch.
