Buzzing noise when using the front garden faucet
  • Buzzing noise when using the front garden faucet
    Hi,
    I have a problem with a front garden faucet, when I turn on the water faucet to water the garden, I can hear the buzzing sound coming from the faucet. This is a 2 story home. It is annoying, how can I stop the buzzing noise when ever I am using this faucet.
    Thanks!
    Re: Buzzing noise when using the front garden faucet
    check to make sure the valve to the sill cock is all the way open first then check to be sure the washer in the sillcock is tight, it may be loose causing the chatter or buzz.
      I will totally ignore the fact that you are a beekeeper and you hear a buzzing noise. That's just too easy
      Vacuum breakers on hosebibbs can sometime 'buzz'
        Can you describe the Buzz???
        If the the buzz is very buzzy it may be a sign of a larger problem. I recommend that you contact a licensed plumbing professional in your area
          Originally posted by BeeKeeper View Post
          Hi,
          Thanks!
          GET OUT OF THE HOUSE NOW!
            I think this question is better suited for the `Ask the plumbing experts`section.
            As for the buzzing I would definitely say its a built in vacuum breaker issue..
            West Trail Mechanical Ltd
            www.westtrailmechanical.ca
              Hi,
              Thanks!
              Does it bother your customer that much?
