need help
  • need help
    heres 1 for u guys----
    i have a small bar that has water issues--if you flush 2 urinals, u get a dribble out of the lav faucet or any faucet---heres what i found from investigating
    1--water main comes from house in front of bar--3/4 main enters home and is reduced to 5/8 meter and then has 2 3/4 meters after it---1 is for bar and other is 4 other property( cluster of 2 homes and bar behind) main to bar is 3/4 copper
    2---3/4 copper enters bar behind new 45k dollar wine cellar and after ball valve thats inaccessible it reduces to 1/2 copper---1/2 then runs to second floor and directly to hwtank--there is about 60 ft of copper upstairs of each cold and hot--1/2 of each is 3/4 , the other half is 1/2 " copper---main is on 2nd floor and supplies down to 1st floor
    3-there are 2 restrooms-- 1 mens with 2 urinals and 2 toilets, and 1 womens with 2 toilets--each has 1 faucet------there is 1 employee r/r with 1 toilet and faucet ----------there is 1 3 bowl prep sink, there is 1 hand wash sink and 2 bar sinks
    4 at the meters, i had 60 psi and about 17 gpm---
    5--- i think the restriction in pipe size is the main problem, and this guy wants this solved quick with a booster pump
    i dont think booster pump is the answer unless i get a large storage tank with float system--i know main should be 2" and it cant be changed--there is a new 60 k parking lot in the way and 2 homes--not an option--dont even suggest--i know it needs, but aint happening----also, the 3/4 main reduced to 1/2" needs changed, but cant either--the new cellar is on it and it cant be accesed through or around---dont suggest, cuz it cant happen either
    heres my issue---i have a nice grundfos booster system that will build any gpm and pressure from atmospheric---how big of storage tank and what kind of float system or low water cutoff in emergency situation to avoid dry pumping----
    again the 2 things that need done cant happen, if u saw this u would understand--so with that in mind, what can i do or what size tank and how to keep from running dry????ask away--i need help
    jason
    Re: need help
    "3/4 main enters home and then is reduced to 5/8" meter"
    Explain this setup a little better please.
    Thanks.
      Re: need help
      there are 2 homes with the bar behind them---the water for all 3 is in 1 of the homes---off the city main, 3/4" pipe enters the home--it is reduced from 3/4 copper to a 5/8 meter--then runs 10 ft before it tees to 2 more meters--one 4 bar, 1 for other home
        Re: need help
        I am suprised they got away with this setup. I would guess it would have to be changed if the property were to ever be divided up and sold. 5/8" meter reduces the pipe to 1/2" thread. Waaaaaayyyyy to small to be feeding two houses and a commercial business.
          Re: need help
          Gotta' say I'm confused. I know you're skilled and have exhausted some options. But are you saying there is no access to this 5/8" meter?
            Re: need help
            and there is no backflow preventers either---what to do???????
            if i can figure this one out, ill add backflows in my quote-
            i need a storage tank to fill and pump from it in bar---suggestions on size?????
              Re: need help
              there is access to all meters, they are in house up front----no access to main in bar----it enters in bar behind cellar from house in 3/4" and has a 3/4 by 1/2 " red. coupler that runs 1/2" to 2nd floor
                Re: need help
                apparently no permits were pulled when 150 k remodel was done 3 years ago to bar
                  Re: need help
                  I don't think you can calculate a size without knowing turnover rates for usage. WrenchSpinner is the resident engineer.
                  Never ran into one where there wasn't access to the meter and piping in/out. Learn something new everyday.
                    Re: need help
                    First, I'd change the 5/8" meter even if you end up with a pump/tank setup.
                    And can you connect behind the 3/4" by 1/2" coupling? Make it all 3/4"? Wouldn't look bad exposed in most bars. Shiny copper (for a while) straight and braced.
                    Also, I could swear I recall seeing very large bladder tanks that helped with this. But I HAVE NOT installed to solve problems such as yours. So I could be thinking out of my rear.
                      Re: need help
                      You can put lipstick on a water service, but if it's garbage, little water. You're a plumber , not a magician!!
                        Re: need help
                        In my mind I'm trying to avoid a pump & tank system as that's more maintenance.
                          Re: need help
                          more maintenance, but they have volume and pressure ---and im the hero
                          its the only way
                            Re: need help
                            Gotta' know the turnover rate vs. incoming volume & pressure imo. Might need an engineer to get exact. Or oversize.
                            So, I'll ask the dumb question to whoever.
                            What would a large bladder/well tank placed on the second floor do for this situation?
                              Re: need help
                              that bladder tank would increase pressure only---i need volume---not pressure---
                              thats why i need to fill storage tank and pump from it to make 60 psi and provide the volume i need----
