40 year old DWV lines
  • 40 year old DWV lines
    Started pulling lines and look what I find 40 years of use
    Re: 40 year old DWV lines
    Shut er down Virgil!
    She's pumpin' mud!
      That is not to far from true... the sludge has the consistency of clay....
        EWWWWWW looks like grey ice cream! Something tells me this is going to turn intoa k-60 vs. k-7500 thread!
          5/8 cable would've handled this easy. Bioclean might have also been a good idea.
            How dirty are these people using that shower?
              Regarding a point I made with you recently, the picture of the cross section shows what I was saying regarding a bulb auger...I just don't see that type head clearing a substantial amount of that goo.
              Bee's still buzzin' in the ole bonnet, just observing meanwhile.
                For that Mark, you would need the 4 bladed cutter. But you could just get a 3/8 cable and you would be covered for a situation like this. A 5/16 cable w/ bulb auger will cover you for most 2" and under lines. The same gun will run both cables.
                  Who makes 4 bladed cutters for general and ridgid?????
                    Ridgid the 3/8" cable is C4 or C6 and the 4bladed cutters are T-213, 214,215.
                      if you say so
                      the 7500 is too big a machine for 2'' pipe. plus getting in under the house is not going to happen.
                      the k-60 with 5/8'' or even 7/8'' with the 4 blade cutter should breeze through it.
                      of course if the entire line was pvc, then a good washing would have cleared and cleaned it.
                      thanks wrench, you gave me the angle to talk k-60.
                      who's keeping score
                        Years ago in plumbing and mechanical Mag, I read this. It's smarter to replace that 2" Galvey,with abs or pvc than to play with it. What say you???
                          agreed!
                            Guys,
                            I don't have much experience in drain cleaning mainly simple kitchen santee when replumbing kitchen sinks, shower trap and easy access main. Just picked up a K-39 and a Marco with 5/8" Both have been great for what I've run into so far, so my question, if I run into 20' of 2" that looked like Okies picture would a 4 blade clear the line? How does it get flushed down if lets say you're accessing a cleanout outside a kitchen run? Seems like the blade would just act as mixer and not move the gunk, If I was able to get some head pressure would it move the gunk down? Job for a jetter?
                            Thanks, wookie
                              I should have titled this thread Hospital Nightmare part 3.
                              This is the same hospital I have been working on....
                              I have been replacing these line sections 20 feet at a time w/ sch 40 PVC, this hospital has a good sized crawl space but there are some really long crawls...lol
                              Okie
                              Wookie: I went for replacement due to the length of these runs (2"x50') and how flat they currently are, as I'm repiping I'm adjusting slope. The consistency of this muck is harder than normal but with normal muck cutting w/ a 4 blade and lots of hot water flushing makes a big difference. If I was not replacing and fixing other problems this would be a perfect job for a jetter...
