Softener problem
  • Softener problem
    Alright guys, got the call last night. Put in customer supplied Kenmore softener about a year ago. Customer calls and said they can hear it working every now and then but have never had to add any salt to it. What was the problem?
    Re: Softener problem
    Slider valve on the back is in bypass position. ( water is bypassing softner)
    That or the valve / head is stuck or faulty...
    Okie
      That or the valve head is stuck or faulty...
      Okie
      Nope, metered softener in service position showing water flow. That was my first guess though.
        I just had a kenmore softner that the membrane in the resin tank ruptured and let the resin into the plumbing.... most of it settled in the water heater what a mess!!!
        Is it pluged in?
          Air leak in the suction line for the brine tank.
            Yes it is plugged in and no air leaks.
              Is it piped properly? (Inlet and Outlet / not hooked to only the ice maker line ect...)?
                where's the manual? You didn't throw it out did you?
                  You guys are way off. I will give you a hint. This was probably my fault during installation. Come on guys, there is a lesson to be learned here.
                    Drain line issue?
                      Did you not set it to regenerate or the hardness setting at zero?
                        You did plug it into a working outlet?
                          Nope, cycles and drains just fine. Just does not use any salt.
                            Lost interest.
                              I guess so. Anyways the problem was a salt dam about 5" thick with a void at the bottom. Probably caused when I added the initial water to the brine tank. Salt got wet as the water passed through it and dried to form a very hard salt dam. Word of advice. Make sure you add the initial water to the brine tank through the brine float valve tube, or before adding the salt. Not just pour it through the dry salt. I have always just poured the water in and never had a problem, until now.
