Back Up Sump Systems
  • Back Up Sump Systems
    What back up sump pump systems are you guys using? I realize that some may not install these at all based on location.
    It seems that water powered pumps are taking over the market share on battery style back up pump systems. At least around here.
    www.firstresponsedrain.com
    Re: Back Up Sump Systems
    Some are really opposed to water powered backup systems because of the potential of potable water contamination.
      I've never installed a water powered backup system
      I have seen dozens of battery backup systems fail because the chargers were either unplugged and batteries drained out or not replaced on the required schedule
        Water backups are illegal here b/c they are a cross connection---sewer/ water
        i use zoeller battery backup with no callbacks---ever
        water backups are dangerous and unsafe---if ur a plumber using one here--look out--they will crucify u if caught
          And if u suggest a backflow on it--it would have to be an air gap---which would not work
            I too use Zoeller Aquanot II systems for my back ups. I love the system but it is so pricey.
            After all of the rain we just got here my phone is ringing off the hook for backup systems. I am losing out to these guys installing water powered systems at a 1/4 of the price.
            I will stick to what I know is right and keep pushing the Zoeller unless someone on here knows of another battery system that is decent.
            Don't even mention the WatchDog either......JUNK!!!
              I love ripping out new watchdog junk that fails in 1st storm---stick to zoeller---when it rains heavy--i install tons of backups
                Are you allowed water backup in ur area????not here
                  Does Liberty Pumps make something comparable? I've heard decent things about them but have only worked with Zoeller myself.
                    As far as i am aware...Yes.
                      Just looked at a Liberty Model 441. Looks kind of plasticky.
                      I like ones with cast iron bodies & metallic impellers.
                        I install the Pro Series brand. No problems with them. Never seen or heard of anyone using the water powered in this area.
                          Looks like they utilize a vacuum breaker. The pumps are cheap. But how much for running the copper? The majority of sumps I see are not near water lines. Unless hacks are running a garden hose for the hookup.
                          LOL...the Zoeller one pumps 364 gallons per hour, if you have 60psi! Start building your Ark!
                          http://www.acehardwaresuperstore.com...15.html?ref=42
                          http://www.proseriespumps.com/backup_sump_pump_1000.htm
                          Twice as much as a Pro Series installed...but you will be drier!
                            BINGO!!!
                            The ones I have seen have had copper run to them from far across the basement. I'm sure they charged an arm and a leg for that copper line.
                            They do work but I would not trust one. It pumps 2 gal. sump water to one gallon potable.
                            Doesn't seem very great.
                              Typically, the sump pump crocks in this area are right near the washing machine or water softener. An easy way to plumb in a connection. I have seen many people utilize a Y fitting on the washing machine boiler drain, and just install it via a washer hose. For battery back-up systems I typically use Wayne. Not the best, but affordable.
