Surgeons Tools...
  • #61
    Re: Surgeons Tools...
    I rough in/remodel also. Have to cut lumber for support, backing, bracing-you know the drill. So I keep it in there too.
    No,No.Sorry
    I was replying to another poster.
    Remember,I like it
    • #62
      How are jumper wires useful for a plumber?
      What about for jumping thermostats for a boiler/furnace?
      • #63
        Here Charles, no plumber would look at a furnace. Only about 5 boilers in the county. And I'm being serious.
        • #64
          you could use them to jump a pressure switch on a well
          • #65
            or nipple clamps of course
            • #66
              Then I guess you could figure out a way to use them on your deadbeat customers.
              • #67
                Rethunk it.
                • #68
                  Just push the points in with an insulated tool. Built in jumper. No sermons please.
                  • #69
                    I think I would unload all the adjustable crescent wrenches and get a few double open end wrenches: 7/8, 13/16", 3/4, for 5/8" compression adapters and stops, 5/8" for the 3/8 comp nuts, 1/2"x9/16 for the tank bolts and closet bolts, 3/8"x7/16" for the smaller closet nuts and thermocouples. I find they don't slip like the adjustables are apt to.
                    I'd carry a 6" square piece of rubber gasket material-various uses-especially for plugging the whole when you pull out the old ballcock so you don't have to use your turkey baster to drain the whole tank. The end of the ballcock box will do almost as well.
                    Sponge
                    Pair of regular scissors for cutting fill tube on the ballcock or labels off of most anything or opening plastic bags or those tough plastic containers that the new tools you buy come in. I suppose the razor knife would do the trick but I could tell you some bad razor knife stories (ouch!).
                    String packing
                    A couple of different size scratch awls
                    I prefer douglass or speedy channel locks
                    • #70
                      Thanks Tim. I'll consider some of your ideas.
                      For W/C assembly or dismantling though-I can turn & burn with the deep sockets w/small ratchet. With good control. Tried nut drivers too.
                      • #71
                        Good idea. I'm glad you have good control. I'd end up busting the tank if I used sockets.
                        I also carry my dewalt cordless screwdriver and a small case of bits and drills.
                        • #72
                          Be careful with ANY new American Standard toilet. Got to almost crack the S.O.B. to get it to stop rocking. Regardless what type of wrench you use.
                          • #73
                            Agreed! Dang, you're up late.
                            My last tool suggestion for the evening: A little micro-torch (the kind that use the butane). The small intense flame is great for loosening faucet handles, screws (especially in the end of an old tub stem) or practically any metal things that are stuck.
                            • #74
                              Yes, I'm up late. And so are you! Gotta' turn the dryer on again to make sure the jeans are dry for tomorrow. Knockin' out soon though with wrenches and bolts dancing in my head.
                              • #75
                                Have you been in my tool box? They sure llook like tools right out of my box.
