Pex rumour
    Re: Pex rumour
    Originally posted by Scott K View Post
    Like I said - he said PLASTIC - CRIMP - RINGS. He's not stupid, he wasn't born yesterday.
    Hey Scott did you ever find a link for the plastic rings, or hear anything more about them?
      Re: Pex rumour
      How long do you think plastic fitting are gonna last ?
      The Garden hose is sounding better and better
        Re: Pex rumour
        Are you referring to the plastic expansions rings, the plastic crimp rings or actual plastic fittings?
          Re: Pex rumour
          according to Wirsbo, the PEX and rings are forever clamping down on the fitting, and therefore cannot come loose..... It seems to work pretty well, but it's a bummer sometimes that you can't dry fit with their system.
          a PLASTIC CRIMP RING??? I've not heard of one, and would not likely trust it EVER.
          But I also resisted using the copper crimp ring system...
          Garden hoses? sure why not? Everything else in building construction is getting disposable, why shouldn't plumbing? (it's hard to type sarcasim )
          We can start running DWV with garden hose too... better add a grinder pump to every toilet though.
            Re: Pex rumour
            Left out the S
            plastic fittings
              Re: Pex rumour
              Left out the S
              plastic fittings
              The last time I asked about them at the wholesaler they said they they did not sell any of them (the plastic crimp fittings). The plastic Uponor Quick & Easy fittings (many people call them wirsbo fitting) are very common around here.
              * the plastic fitting I was referring to were for "crimp" style fittings. I did not ask what type of crimp rings were used on them (maybe they are the plastic crimp rings Scott was talking about)
              *Uponor has black plastic fittings that use a plastic expansion ring. http://www.uponor.com/en/Solutions/P.../Fittings.aspx
                Re: Pex rumour
                I don't think there is any such thing as a plastic crimp ring. If there was I'm pretty sure one of us would have heard of it by now.
                • #23
                  Re: Pex rumour
                  Ranger ole buddy, where in hell have you been?
                  • #24
                    Re: Pex rumour
                    Still around and staying out of trouble.
                    • #25
                      Re: Pex rumour
                      Where's the fun it that?
                      • #26
                        Re: Pex rumour
                        I am not a fan of pex. It never looks good, I dont see a savings.The manifolds are junk!! I always try to talk them into CPVC.
                        • #27
                          Re: Pex rumour
                          Funny how we all have different opinions and like different materials, makes it interesting for sure. In over 20 years of plumbing I've never installed a single stick of cpvc and never will, I just don't like it.
                          These days I do use Viega Pex with the stainless steel sleeves, love the stuff and when I'm done it looks good. I also use copper too but only use the ProPress fittings and they look great!
                          My rates for the Viega Pex are about the same as if I was using copper with sweat fittings and the ProPress jobs are a premium. I don't think I'll ever go back to running copper with sweat fittings. Viega makes both the copper Propress and the pureflow pex, this company changed the way I do business. Thank you Viega, and thank you Ridgid for the tool!
                          • #28
                            Re: Pex rumour
                            Another use for wiersbo rings is to Hold the head on your snake in an Emergancy ... But they are excellant on hose fittings
                            • #29
                              Re: Pex rumour
                              Residential fire suppression is coming around for plumbers
                              Taking a class at the uponor factory in March to learn/get certified
                              on the fire side of all this.
                              Should be interesting.
