Pex rumour
  • Pex rumour
    I heard a rumour from an inspector the other day that apparently that someone might be making or already makes plastic crimp rings for pex. Is this true?
    Re: Pex rumour
    I havent heard anything about plastic rings but have seen plastic fittings at the supply house. They said that they have sold hardly any.....
      Re: Pex rumour
      Is he getting it confused with the wirsbo expansion rings?
        Re: Pex rumour
        Plastic rings are for Aquapex expansion type connections it's made by Uponor.
          Re: Pex rumour
          Come on guys - give me some credit here - I ain't stupid, nor are my inspectors. He is talking about PLASTIC CRIMP RINGS, yes, PLASTIC.
          I can tell you that there is one pex installation I am proud of. It's when I'm using Rehau Raupex UV barrier red & blue pex pipe, with the Rehau everloc system, supports at the proper locations going through plates and studs (PC & IC clips) to reduce stress on the joints, and with open plastic 90 degree support bends at required locations where you might have previously used 90's. Perfectly drilled, studs or joists so when you pull the pipe it looks straight and it all is parallel with each other as well as you don't scrape the crap out of it when pulling it, and you have a pretty damn good looking installation as well as the fact that you know it will last a long time because the pipe is protected & supported properly. Yes this is an expensive version of the pex system but it's only seen in about 2-5% of installations, where it is done properly.
            Re: Pex rumour
            i ran into these today. ironic? i think not.
            these are on a 3/4" PEX line the guys had to due last year during the big freeze.
            i don't have alot of experience with pex. but i am learning.
            sorry about the quality. i'm still trying to learn how to use my camera.
              Re: Pex rumour
              Vince, don't you have a big freeze EVERY year?
                Re: Pex rumour
                Nope - that's not what I'm talking about but thanks for the Pics. That is the Wirsbo/Uponor system that you picture. Those white rings you picture are put onto the end of the Wirsbo pex, and then you insert the Expanding tool into the pipe and expand it and then quickly insert the fitting into the pipe and the ring slowly shrinks the pipe around the fitting.
                What I'm talking about is take your standard pex crimp ring that you would use on Bow Superpex or similar with a set of crimpers, and now it's plastic. That's the rumour I heard about.
                  Re: Pex rumour
                  I'm pretty sure we're one step away from garden hose fastened with hose clamps.
                  I'm already honing my pitch to homeowners:
                  "Well yes Mr Smith..I only use the highest quality garden hose with industrial strength clamps on my work."
                    Re: Pex rumour
                    No joke we re piped a whole basement that the H.O did with garden hose and extension cords so he could sell the place.
                      Re: Pex rumour
                      Here's an interesting tidbit, speaking of gear clamps & garden hose. I have used, successfully and on multiple occassions, Wirsbo fittings & rings, to repair rubber hoses, as opposed to those gear clamp repair coupling sets they sell at HD. I tried this after getting and sick and tired of waiting for the boss one day to get me a gear clamp to repair a leaky hose (that we use for testing). So I said, might as well try it out and see if it'll work.
                      And it works great, and the nice thing about it is when you're pulling the Wirsbo repaired hose around to test various systems, you don't have to worry about a gear clamp catching somewhere or cutting your or coming lose somehow.
                        Re: Pex rumour
                        I don't think that plastic crimp rings would work. I think the inspector saw the expansion product and thought it was a crimp ring.
                          Re: Pex rumour
                          Test rigs, the best thing for them belive it or not a sharkbite. Reusable and fast/non destructive.
                            Re: Pex rumour
                            They had that already in NC and some other states years ago and then we got paid to rip all that crap out and replace it with copper
                            I doubt that, How would you crimp it? .....with heat?
                              Re: Pex rumour
                              Like I said - he said PLASTIC - CRIMP - RINGS. He's not stupid, he wasn't born yesterday.
