Bradford White Flue
  • Bradford White Flue
    Check out the Helical Fin Flue in the Bradford White High Performance Water Heaters. That's wicked looking.
    Re: Bradford White Flue
    Another View
      Would someone crunch these #'s for me. 5 gpm doesn't sound like much to me.
        I just got through reading Vince's post on their code change due to the Legionella bacteria. So, I might as well post these last two pics with regard to the mixing valve at the top of the bradford white hp tank. (Also because I know how you folks love photos and attachments-maybe this will keep you off the porn sites.)
          look at bock water heaters, they designed that flue system some years ago !
          JERRYMAC
          E-MAILJERRYMAC777@GMAIL.COM
          FIRE SPRINKLER CONTRACTOR,
          SINCE JAN. 1989
            I'd never heard of a Bock WH until you mentioned it and I googled it. Are they used in Utah a lot?
              All of the Bocks I have ever worked on were #2 fuel fired with gun burners. (I'm sure there nat gas burners are just as good).
              It is good to see a technology trickling down into what will in the future make it into standard residential units...
              Okie
