Sweating 2 1/2" valve advice
  • Sweating 2 1/2" valve advice
    Need to replace 2 1/2" valve. I have sweated 2" copper on pool equipment using two mapp turbo torches with helper. Will I have success using same game plan? I have 3 torches available and a helper. Go with different setup-O/A maybe? I understand clean/ream and solder following heat just no hands on with the larger sizes. FYI I'll be using Everlast flux and Bridgit solder.
    Thanks for any advice!
    wookie
    Re: Sweating 2 1/2" valve advice
    Heat that brass good... I would get a big tip torch head, and have a helper solder.
      What Big Jim says....
      Heat the pipe end and drip solder on it than quickly wipe it to spread solder.... Rotate pipe and repeat... Lots of flux... Once end of pipe is covered sand it down a bit for fit than put pieces together and solder as usual.
      This technique makes sure you get enough solder into the joint...
        I use a weed burner [ propane ] to pre heat ,before welding anything thicker than a pencil.
        Would this help with large copper ??
          Clean valve + pipe end thoroughly. Even coat of flux (i use kester) on both pipe and valve as well as evenly dispersed heat from a B tank will give you good solder flow.
            wookie, a suggestion might be to get 2- mip adapters and an ips ball valve.
            using a torch that is too small will not only cause a poor joint, but also damage the valve as the heat required to properly solder a large 2.5'' brass valve, the valve will absorb too much of the heat and cause damage to the teflon seats and packing.
            advantage of the mip adapters is less mass and no damage. plus you can see and feed solder from both ends if necessary.
            personally an acetylene b tank will do a great job. a handheld mapp torch is a bit on the small size.
            a propress crimp will do the job with running water in 4 seconds a side.
            i do some propress for other plumbers just like you
            you don't want to do it twice
              Call someone with a propress--or rent it from supply house---odd enuff, ive done quite a bit of 21/2 " copper with the press lately---real odd size here
                up here in canada we have a torch kit called "Turbo Torch". it hooks up to a 20lb propane bottle.
                it has various size tips. larger diameter pipe only requires a tip change. there are some pretty serious tips available.
                one draw back to this kit is that the gas flow is supposed to be set at one setting, full throttle. this is to prevent damage to the tip. it will over heat if used at a flow rate less than recomended factory settings.
                if you don't have anything like this available where you are i could look into it further for you.
                cheers
                  vince, i have a turbo torch that look like the exhaust pipe from a 4 banger.
                  this hooks up to the propane tank directly, no regulator.
                  turbo torch is probably the #1 maker of torches for us plumbers.
                  have both the propane and the acetylene set ups.
                    cheers
                    I lobe my turbotorch,
                    Sorry just had to add that
                      i have bin a pipe fitter for 20 yrs and never pre tin a pipe
                      i have done up to 6" pipe and all i use up to 3" is a Turbo Torch / b tank with a a-14 tip .
                      do not over heat your pipe and valve
                      rick good pipe fitters dont need pro press
                      sorry rick
                      but i still like you
                        sorry rick
                        charlie, 5 years ago i would have agreed with you
                        but when the water doesn't shut off 100% and you need to get it done, what are you going to do?
                        propess is 4 seconds, or a loaf of bread while you wait for it to drain
                        sure i have jet swets to 4'' and pipe freeze equiptment too. but 4 seconds is impossible to beat.
                        don't make me dig up some pictures to show you my
                          your right
                          but trying to get my boss to agree is not going to happen
                            sorry rick
                            Hawk: You have "soft" soldered 6" copper pipe and not tinned? I believe you can get the solder to flow you can even get the solder to seal but without tinning I can't believe you get the joint full like it should be.
                            I have seen your work and will not doubt your skill's though.....
                            Okie
                              Holy leaping horn toads Batman, man up and put some heat to it. Turbo Torch T6 tip.
