Not my cable (Pics)
  • Not my cable (Pics)
    Rental property Sink clog....
    I pull the trap apart and look in the stub out and what do I see?
    ( this is after I cut things away)
    The previous plumber had gone down the roof vent and left a present in the line The owner called the last plumber that worked on the sink (3 days ago) who could not get it cleared, of course he knew nothing about this...
    I'm the guy who is going to try to get it out...LOL
    The cable is a 5/8" Ridgid open wind sectional cable...
    It appears that the last plumber did not put his cables together properly which contributed to this issue.
    My plan as of right now is to pull the sink for a bit of room and get after it with an engine lift, or an AT forklift through the window. An electrician friend is loaning me a cable sock / cinch (think chinese finger cuff with a 65K lb break strength)...
    This line is an 1 1/2 copper line running through / under concrete, my plan is to pull till it breaks.... If it breaks we will run new line around front of house through garage to backyard for tie-in...
    Either way this one is going to be an interesting job in Hacktown.
    Do you think I will have any luck pulling???
    I'll take lots of pictures.
    Okie
    Re: Not my cable (Pics)
    i'd put alot of dish soap in first and try to hook up a hole hog in reverse
    i dont deal with sectional cables though? i'd like to hear how it goes though?
    Mike
    www.plumbinginclarkcounty.com
      Agree; find a way to rotate the cable in reverse. I assume you've tried just pulling on it. You may have a busted line and end up replacing it anyway as something's got ahold of that cable. When you get it out, call up the first company and tell them you've got some used cable for sale.
        Yup you need to rotate it, pulling it is asking for it to break
          1/2 drill in reverse is what I`d do and I bet I could get it out.
          Great post!
            I will try the Hole Hawg in the morning, I wish I could get the cable to chuck into my HILTI 92.
            Did I forget to mention the collapsed washing machine line that was rerouted (to this sink). The old washer line tied in about 15' down stream to this line...
            okie
              Do you not own a k 50 ?
                I do not own a K50 though I do own a K60 that could do the job
                  forget the drill the hook it up to the k 60 and give it hell. If it breaks go to plan B
                    bill, do not use a drill. use the k-60 so you have a better feel and a quick acting clutch.
                    did the cable just come apart at the connector?
                    it might just need to be run in reverse to let go of the problem
                    don't try the drill
                      Rick,please explain why the drill is a bad idea. Thanks tool
                        first of all the 5/8'' cable is probably too large to chuck up in most drills.
                        the drill will not have a fast way to stop it. there is no real feel. since he has a k-60, he can easily treat it like it was his cable and drain.
                        the object is not to break the cable, but to remove it. the k-50 or 60 is the proper tool for the job.
                          Are You concerned About getting paid for this project? It looks like a lose lose for the poor homeowner! Good luck Tool
                            No concern about getting paid for the job as the owner is of this rental is a good guy (I have had a few dealings with him in the past)...
                            I'll put the K60 on it this morning.
                            Fingers crossed
                            Okie
                              i got to thinking about it last night if the other guy didnt connect his cable properly it might not be stuck to bad. good luck
                              Mike
