Question for the pro's
  • Question for the pro's
    Went on a drain cleaning call the other day and cleaned the drain through the cleanout located in the attached garage. Almost got an instant headache when I walked in there and noticed the WH was at one time B-vented through the garage roof, but a piece was conveniently taken off from the top of the heater. I offered to fix that for him, but he said "No way, that is my only source of heat out here." Anyways, he wanted me to replace the heater too, but I told him no way. My question is would any of you replace a heater if you knew beforehand that as soon as you left, the homeowner was going to remove the vent to heat his garage? Sometimes you just can't fix stupid.
    Re: Question for the pro's
    Hmmm... probably not. If they find him dead and see that a water heater was just replaced and a piece of venting is off, guess who's family is going to sue you.
    If you want to have fun with it, you could call the police and say he's trying to kill himself with carbon monoxide. Just a thought
    I’m back
      Hurry up and cash the check!
        Sounds like a canidate for a Darwin Award.
          just playing the devils advocate here,
          but if the flame is adjusted correctly, (not saying it is), how much different is the safety of that verses the unvented wall heaters that are sold in many places. or a gas range?
            You can't fix stupid. But maybe you can help it.
            Tell him to get a CO detector and plug it in. Might go off once in awhile with cars but will also warn him if levels get high from the heater in the garage.
              install the heater, take a picture and call for inspection.
              then you're covered.
              make sure to screw the single wall together.
              no screws on type b venting
                Burning correct,the CO should be no more than .04%
                I would still hustle to the bank!
                Inspector has your back on this without question.
                  I second that.
                  Except for Devine would need a license in order to get a permit.
                    I'd be calling the gas company and having them come out, shutting him down.
                      Protect yourself, your billing should state in detail your observations, warnings regarding the consequences of his failure to heed your cautions and a proposal to bring this situation up to code along with a stiff statement providing verbage regarding your detailed conversation with him and his acknowledgment of his total disregard. Sending a copy to his wife will either result in the job being taken care of or he'll call someone else to do it.
                        I agree with Dunbar - call the gas company. Anyone who argues about connecting a gas vent belongs in a mental hospital.
                          The first thing you should have done while you were there was shut the gas valve off to the heater and noted this on your invoice and have him sign it.
                          Sure, he gets pissed and maybe never calls you again but the fact that you got a headache indicates to me that the burner is somehow impinged and likey creating dangerous levels of CO.
                          If he wants to kill himself, tell him to buy a gun like everyone else
                            Originally posted by Service Guy View Post
                            I second that.
                            ROTFLMAO
                              Whats wrong with screwing B vent? I've ran miles of it from 3" to 12" and I screw it just like its single wall.
                              In this situation I'd feel much better about installing a new heater and letting them take the vent pipe off, versus letting it go the way it is. A new heater will be making well under 20ppm, more likely 6 or 7ppm. Even if they did remove the vent pipe from a new heater the air in the garage would never saturate to the co levels that are being emitted from said heater. And even if it did, who cares. 6 or 7 ppm is nothing. Whereas an old heater thats improperly adjusted could very easily be making over 1000ppm. That could very easily saturate the air in the garage and kill someone in a few minutes.
                              Andy
