Cutting 4 in ductile
  • Cutting 4 in ductile
    Chop saw, or partner saw? I seem to remember using either one. Thanks.
    Re: Cutting 4 in ductile
    we always used partner saws
      I would think a quick saw.Didn't Bob post a video a couple of weeks ago on this?
        Spoiled welder. porta band, 14" hilti gas,plasma cutter, 1 H.P. 7"x12" metal band saw.
        14" chop saw= TOO MUCH NOISE
          This is what I had in mind...
            i would use a plasma cutter
              a gas cut off saw is the way to go. the pipe is way to heavy to move it onto a chop saw.
              if installed in a ditch and you need to make a field cut, 2 saws would be better.
              one with the guard in the normal position and one with the guard upsidedown for the bottom part of the pipe.
                wheeler rex also has a hydraulic snap cutter rated for both class 22 and class 26 cast water main.
                http://www.wheelerrex.com/catalog/Wh...Catalog_05.htm
                it just so happens i have 1
                personally, i've never tried anything except cast iron with it.
                not sure if ductile iron is the same as class 22/26 water main.
                all i know is that i had to destroy some old ductile iron pipe and all a sledge hammer did was bend it. it never broke.
                  If you try to cut ductile with a chain cutter you will break the chain. I"ve seen it done more than once,
                    I rented a gas saw for the cut (if needed). I also ordered a special blade. Thanks for the help! Goob...you like Avanti's?
                      Right now I'm using a 71/4" ferrous cutting"Tenryu" for steel.If one takes his time they last.Don't have the diamond for iron.
                        Only live 1 mile from the new one on knoxville ave that opened this year.
                          I grew up with the owners sons. Along with Agatuccis...great pizza.
                            Good pizza at both places , but aggies is a farther drive after a few cold ones.
