Gas Regulator
  • Gas Regulator
    I am involved in a natural gas water heater replacement. The original has a pressure regulator in the gas line right before the line goes into the burner control. I have never seen an application with a regulator only at the water heater site. Usually the regulator is installed outside the house at the meter, controlling the pressure for the whole house, not just for one appliance. Any ideas why a separate regulator would be found at the water heater?
    it could mean its a 2pound gas into house what dose every other equiment have jeff
      This is very common where I live, do a pressure test downstream of the reg. If the pressure is within the reccomended inlet pressure of the tank theres no problem.
