Orangeburg cleanout ?
    Re: Orangeburg cleanout ?
    That soil looks like PV rock. That stuff doesn't shift or compact easily and is more solid than a dried out cow pie. I bet the pipe itself, other than some roots, is in pretty good shape which is why you're willing to install a cleanout I'd bet.
    I would go with 4X4 mission CI-PL flex seal couplings and a two way. I would go easy on torquing the bands though. Might squash the pipe. Looks like maybe another 10-12" of digging to the right should give enough room to fit it in. That's my 2cents FWIW
      I would go with 4X4 mission CI-PL flex seal couplings and a two way. Then again, some good ol shielded no hub couplings might add some rigidity. Looks like maybe another 10-12" of digging to the right should give enough room to fit it in. That's my 2cents FWIW
        Here ya go Rick. This is the right one for Orangeburg. It`s a "MR 51-44"
        If you use the one for plastic on both ends you end up like this by next year
        Make sure you concrete over the fernco`s because the will leak on Orangeburg and the roots will get in
          Originally posted by All Clear Sewer View Post
          Here ya go Rick.
          Who are you and what did you do with Steve?
          I love my plumber
          "My Hero"
          Welcome, Phoebe Jacqueline!
            is this better ?
              HE'S BACK....now things are back to normal
              The Other Rick
                is this better ?
                I don't know about better, but definitely more you
                I love my plumber
                "My Hero"
                • #23
                  • #24
                    All Clear makes an interesting point in regards to packing concrete around the mission or fernco bands , we used to go one step further and mix copper sulfate (RD or Hercules) root killer right in to our concrete. It works as a great root deterrent when you have to repack a concrete hub.
                    • #25
                      If we see roots in our holes we always dump rock salt in also.
